VW Passat B5 1997 - 1.6 Engine LPG Combustion: 13L/100km Standard? Reducing/Adjusting Methods
_PREDATOR_ 7659 11
Is 13 L/100 km of LPG normal for a VW Passat B5 1.6, and if not, how can I reduce it?
13 L/100 km can be normal in city driving, but on the road it is too high and should be closer to about 8.5–9 L/100 km [#16200350] [#16200954] Check whether the LPG installation and its components are correct, because something may be wrong there [#16200735] [#16200553] Also verify the lambda probe, ECU errors, and learned lambda values, since a faulty lambda-related reading can raise consumption [#16200553] [#16200774] One reply specifically warns that the coolant temperature sensor (NTC) may be faulty and keeping the engine rich, so it should be measured with a tester [#16200992] If you do not know the gas setup or the diagnostics do not help, a visit to a gas specialist/workshop is recommended [#16202770]
  • #1 16199079
    _PREDATOR_
    Help: 1864
    Rate: 2315
    Is burning 13l of gas / 100km a standard, if not, how to reduce / adjust it, or just a visit to the appropriate workshop?
    ELMAX
    Małe Przedmieście 20/4, Olesno, 46-300 | Tel.: 535 XXX XXX (Show) | Company Website: http://ftp.interka.pl/~elmax/about.php
    manta
    Help: 463
    Rate: 1534
    What sections does it look like on the route?
    Ricoh_220
    Help: 464
    Rate: 754
    My octavia 1.6 in the city smokes up to 13l / 100km, while on the road fuel consumption drops to about 8.5-9l / 100km
    So if it's this city don't panic, you're driving for free anyway :)
    I will add that when I step on it sharply, the temporary consumption displays up to 40l / 100km
    Zakład techniki biurowej"Kserograf" .Serwis kserokopiarek i urzdzeń marki ricoh
    Bronowicka 73, Kraków, 30-091 | Tel.: 603XXXXXX (Show) | Company Website: https://kserograf.e.pl
    robokop
    Help: 1763
    Rate: 6373
    Edek, in such a cow and around the city? It's almost a luxury.
  • #5 16200481
    _PREDATOR_
    Help: 1864
    Rate: 2315
    There is no way to change, because I have already 'caught' it :D The problem is that he smokes 13 on the road, not in the city, the fork was at 8, I know it's a 'cow' but a luxury, how much space for a bar ......
    Them s u, that's me over the weekend with a pywk :D .
    ELMAX
  • #6 16200553
    sebap
    Help: 538
    Rate: 1083
    If on the road that's a lot. Something can not be seen what installation, what components. The lambda probe is operational?
  • #7 16200735
    manta
    Help: 463
    Rate: 1534
    Edek, open the diamond about what you have installed from the gas works.
  • #8 16200774
    grala1
    VAG group specialist
    Help: 1496
    Rate: 5053
    Show what errors in the ECU, what the learned value for lambda looks like.
    Golf 4 1.6 8V burned me in a mixed cycle 10. Route 7/8 and around the city 12.
    The wife's Octavia 2.0 8V had the same fuel consumption, or at least it felt like it was going and wanted to go.
    In general, everything ok with the car?
  • #9 16200954
    andrzej20001
    Help: 1578
    Rate: 6675
    Normal combustion for the city. On the road, 9 should be. I had and I know how he smoked
  • #10 16200977
    _PREDATOR_
    Help: 1864
    Rate: 2315
    Not everything is fine, because he smokes hard after approx. 30 seconds. It looks as if he would not smoke at the start of all pots, cables mentioned above. Heck, you ask me for data about which I know nothing :cry: Interestingly, it is the same on petrol and on gas!
    ELMAX
  • #11 16200992
    andrzej20001
    Help: 1578
    Rate: 6675
    Ntc may be dead and he's on the rich. Check the value with a tester
  • #12 16202770
    _PREDATOR_
    Help: 1864
    Rate: 2315
    I don't think it will work without visiting a specialist!
    ELMAX
The discussion revolves around the fuel consumption of a 1997 VW Passat B5 with a 1.6 engine running on LPG, where the user reports a consumption of 13L/100km on the road, which is considered high. Other participants share their experiences, noting that similar vehicles, like the Octavia and Golf, have lower consumption rates, especially on highways. Suggestions for troubleshooting include checking the lambda probe, ECU errors, and the NTC sensor, as well as considering a visit to a specialist for further diagnosis. The consensus indicates that while 13L/100km may be acceptable in city driving, it is excessive for highway conditions.
