VW Golf 4 1.6 SR Engines: Oil Consumption and Potential Manufacturing Defects
goja8721 73623 17
Why does a VW Golf 4 1.6 SR engine consume oil, and is that normal or a sign of a manufacturing defect?
Some oil consumption can be normal on this engine, but heavy oil use usually points to wear or a fault rather than a universal factory defect. The most common causes mentioned are valve stem seals and stuck or worn oil control rings; one owner found the original oil rings completely baked up and replaced them, after which the engine needed rechecking over the next 2000 km [#12657598][#17129115][#17139221] Another reply says it is important to first measure how much oil is actually being lost, because there is always some consumption and the engine condition determines whether an overhaul is worthwhile [#12662208][#12659289] A cited VW tolerance in the thread is up to 1 liter per 1000 km, although another user says a more realistic "normal" figure for this engine is around 0.5 liters between oil changes [#12663481] If the engine smokes blue or the consumption is high, the thread recommends checking cylinder condition and, in some cases, doing a full rebuild with rings and even pistons, not just replacing valve seals [#19019853][#19019836]
  • #1 12657362
    goja8721
    Rate: 20
    Hello, I have a question if it is the norm that golf 4 1.6 SR takes oil. somewhere I heard about that they have a manufacturing defect of rings and so I wonder if it is true? I hope to hear from owners of golf 1.6 SR. my golf takes oil:-( therefore i wonder if this is the norm
  • #2 12657598
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    More often the problem is valve seals that can be replaced without removing the head.From what I have noticed the problem is not the engine-but how it is exploatated and serviced.Golf 4 year 2000 showroom-114tys mileage from new on synthetic Motul 5w40 from change to change(every 15 thousand) takes about 2-3 mm on the dipstick.Buddy has an Octavia with the same engine-newer with similar mileage that "takes" 2-3 liters of oil per 10 thousand kilometers, but drives on the cheapest oils-because why overpay.
  • #3 12657851
    andrzej lukaszewicz
    Help: 626
    Rate: 2121
    Because everyone drives "only on mobil", and about motul, valvoline, quaker state liqui moly have not even heard. This does not change the fact that this engine is not a marvel of technology, on the contrary.
  • #4 12658182
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    andrzej lukaszewicz wrote:
    This engine is not a marvel of technology, on the contrary.
    Of course it has its flaws(fragile throttle)but it does not change the fact that it is a good old eight-valve.
  • #5 12658324
    goja8721
    Rate: 20
    The car is supposed to take oil up to about 10 thousand. however, I have already done about 16 thousand. and after the repair after 7 thousand was an oil change so recommended by the mechanic. I do not know what could be the reason for the fact that the oil continues to disappear. should I go with this to the mechanic who did it?
  • #6 12659289
    j4rek
    Level 19  
    Help: 8
    Rate: 103
    And how much oil does it burn per 1000 km? You don't know if the cylinders were checked during the overhaul, which may already have thresholds on the surfaces.
    If the cavities are not tragic and you know the expected annual mileage and the life of the car, it is worth calculating whether such an overhaul is/was at all cost-effective and how much oil we have for it, e.g. 10W40. You just have to get used to periodically looking under the hood and at the dipstick.
  • #7 12662208
    elemen_th
    Help: 69
    Rate: 183
    Determine how much of this oil is lost, there is no engine that is perfectly tight, always a little oil can consume, there are certain norms for the engines in question, some consume more - others less or even almost no oil.
  • #8 12663481
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    elemen_th wrote:
    Determine how much of this oil is lost, there is no engine that is perfectly tight, always a little oil can consume, there are certain standards for the engines in question, some use more - others less or even almost none.
    The VW standard is a liter(1 liter)per 1000 km - which is an obvious mockery of users !!!
    Normal "oil taking "in this engine is about 0.5 liters from change to change(every 10 thousand).
  • #9 12663554
    elemen_th
    Help: 69
    Rate: 183
    psilos1 wrote:
    The VW standard is a liter(1 liter)per 1000 km -which is an obvious mockery of users !!!
    My friend once drove an astra 1.6 8V from gdansk to warsaw, over this route the oil ran out on the dipstick from max to min :) The engine was healthy, normally topped up 1L for a few thousand but driving at full bump unfortunately caused what it caused.
    I also know a case that fabia (3-4 years old in gasoline) on the route gdańsk-warszawa-gdańsk while driving drank so much oil that due to its low condition jumped the timing gear, the chain tensioning skate stopped pressing. Before the trip it had half the measure and after returning and pouring it down there was not all of 1.5L left.
  • #10 17129115
    golabek08
    Hello, I own a Skoda Octavia 1.6 sr engine designation AKL. The engine was taking me some 1 l / 700km. A week ago I took the engine apart and found that the oil rings are standing. So I purchased a set of rings from Prima, recommended on the forum because of the construction of the oil ring. The condition of the pan and the face was satisfactory. By the way, replacement of seals and timing and head planning. Cost of parts about 500 zł +New oil and 3 afternoons of rummaging. So far everything is fine, but need to do with 2000km ze to see if the overhaul will bring the expected changes.
  • #11 17129503
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    Three-piece rings with spring or the usual ?
  • #12 17134110
    andrzej20001
    Help: 1578
    Rate: 6669
    I had a paseratii 1.6 b5 and it did not chew anything.
  • #13 17134149
    robokop
    Help: 1763
    Rate: 6371
    andrzej20001 wrote:
    I had a Paseratii 1.6 b5 and it didn't chew anything.
    But there you might have had a previous generation of that engine, on a cast iron block. Those actually did not take.
  • #14 17134248
    andrzej20001
    Help: 1578
    Rate: 6669
    Yes the year 98 was
  • #15 17139221
    golabek08
    When I took apart the engine, the rings were the original ones, that is, oil three-piece, baked completely. Now I put on one-piece rings with a spring under the ring. The compression and scraper ring was ok, but I still replaced them all with new ones.
  • Worn piston ring grooves causing oil consumption
    #16 19019836
    Pzzp555
    The engine in a car is not an engine in a tractor .To AKL does not take oil(tossing the rings will not help) you need to replace the pistons because the ring grooves are knocked out And will take oil between the piston And the ring.A set of new rings for new pistons,and new bushings,which have characteristic scratches(after honing) it is by lapping these honing scratches that the ring fits into the bushing.And the engine has no right to take oil.
  • Rusty cylinder bores wear rings and pistons
    #17 19019853
    sigwa18
    Help: 1194
    Rate: 3358
    In 1.6 from VAG the problem is the cast iron block. It is on it that rust forms (as the car stands for a long time especially under a cloud). It is so hard and rough that it wears out the rings and aluminum pistons. Recently I had a golf with 300 thousand and a leon 1M with 180 thousand km to compare. In the leon the pistons were sticking because they were missing 1mm in diameter and more. Lower oil rings could be inserted into the block without squeezing them. The play on the lock about 1.5 mm. Nevertheless, compression even ok only gray smoke behind it. Car used by a friend occasionally. Stands for 1-2 months each then a week of driving and stands again. Golf 4, on the other hand, constantly driven. The difference is that the Golf had a dead head (LPG on the cheap) but the rings still managed . In the 1.6 from Vag when it takes oil and plum smoke behind it is not to delude yourself that rubber bands on the valves will take care of the matter. Rather a complete overhaul sometimes with pistons . Greedy plus is that you can catch fairly reasonably priced parts although even considering the value of the car is still economic madness.
  • Cast iron block wear causing ring and piston damage
    #18 19020569
    robokop
    Help: 1763
    Rate: 6371
    sigwa18 wrote:
    In 1.6 from VAG the problem is the cast iron block. It is on it that rust forms (as the car stands for a long time especially under a cloud). It is so hard and rough that it wears out the rings and aluminum pistons. Recently I had a golf with 300 thousand and a leon 1M with 180 thousand km to compare. In the leon the pistons were sticking because they were missing 1mm in diameter and more. Lower oil rings could be inserted into the block without squeezing them. The play on the lock about 1.5 mm. Nevertheless compression even ok just gray smoke behind it.
    Are you sure you have seen any engine with your eyes?
The discussion centers around the oil consumption issues of the VW Golf 4 1.6 SR engine, with users sharing experiences and insights. Many contributors note that oil consumption is common, with some stating that a loss of 0.5 to 1 liter per 1000 km is within the VW standard, although this is considered excessive by some. Potential causes for oil consumption include worn valve seals, faulty piston rings, and the condition of the engine block. Several users recommend regular maintenance and using high-quality oils to mitigate the problem. Some have undertaken repairs, such as replacing oil rings, while others suggest that complete overhauls may be necessary for severe cases. The discussion highlights the variability in oil consumption based on driving habits and maintenance practices.
