VW Bora 2.0 8V AQY, vibration - Uneven engine operation, high fuel consumption.
heniek1821 10224 14
Why does my VW Bora 2.0 8V with LPG run unevenly, consume too much fuel, and show lambda/lean mixture errors?
The most likely cause is incorrect LPG adjustment or a reducer that does not hold the set pressure, which makes the engine run lean and throws the petrol adaptations off; if the lambda signal still does not switch on petrol after clearing adaptations, the lambda probe itself may be faulty [#16634660][#16641919][#16782300] Check the lambda behavior on petrol first, then on LPG, and reset the learned values in engine adaptation channel 00 so the ECU can relearn [#16634660] Have the LPG map and reducer pressure checked by someone who knows BRC systems, because a bad gas setup can cause jerking, high consumption, and probe errors [#16641919][#16782240] The temperature reading is probably not the main fault: 90°C on the dash can correspond to about 70–105°C in the ECU, so compare the cluster value with VAG and the sensor reading [#16635059] Also verify both coolant sensors in the same housing and make sure the first fan speed works, since switching on the A/C should start both fans in first gear [#16635059]
  • Gas-only fault points to lambda or LPG calibration
    #1 16634280
    heniek1821
    Rate: 8
    I bought Bore 2.0 8V with BRC gas. I have read a lot of topics but I have not found most of the answers to my questions.
    Symptoms:
    - large combustion 17-18 liters / 100km
    - uneven engine operation (rpm does not wave on the clock, but shakes it like jelly)
    - very light shots from the pipe
    - under engine firing to comp. shows the consumption of 50l / 100km and it decreases a bit. I read that the reason for such combustion can be a spent catalyst?
    When connected to a computer, it showed errors:
    - ignition on 2 and 4 ignition
    - lambda probe (I did not pay attention to it at that time)
    After checking the cable plugs etc, I decided to replace the coil. This is how the new art of Beru happened.
    It was even ok only after traveling ~ 150km of vibration, high combustion returned.
    So again connecting to the computer and we have the following errors:
    16518 Lambda Sensor no voltage change (Page 1 sensor 1)
    17536 Mixture too poor page 1 long-term regulation - sporadic error
    Ignition loss is gone.
    After recent tests, I noticed that driving on gasoline, there are no errors at all. After switching to gas and after driving a few km, error 16518 will appear, but the car will still work nicely, in a few days, it will start to jerk again (unless the check lights up early and error 17536 pops up, it is immediately a change for the worse)
    Yesterday I noticed that the counter shows me a temperature of 90 degrees, but after connecting the computer, it shows over 100 on vag and it increases. In this case, focus more on the temperature sensor or thermostat?
    Someone has already fought such a case?
  • #2 16634660
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Check if the probe works properly on PB. If so, what does it show on LPG.
    After deleting the settings learned in channel 00 in adaptations in the engine it should work better on PB.
    You have the LPG set incorrectly or the LPG lambda probe does not work and the petrol map in the engine controller is running down, which causes these problems.
  • #3 16634828
    heniek1821
    Rate: 8
    The probe works properly, after deleting errors or disconnecting the battery problems immediately disappear but not permanently
  • Coolant temperature mismatch suggests sensor or fan issue
    #4 16634850
    g107r
    Help: 811
    Rate: 993
    It's a few days, don't use gas, check 100% if it's not what he wrote grala1 because you probably didn't understand his statement.
    Do you have two sensors in one housing? You had to feel the radiator and hoses then, are they not getting noticeably cooler because the fan was working?
  • #5 16635059
    grala1
    Help: 1495
    Rate: 5052
    There, the counter will show 90 on the counter as the engine temperature will be in the range of about 70 to 105 degrees.
    There are two sensors in one housing, so you should compare the meter reading with the ECU reading.
    It is worth checking if the first gear of fans works because quite often the first gear resistors sit down and the temperature goes up.
    After switching on the air conditioning, both fans in first gear are to start immediately. If they move, you can check the thermal switch on the radiator and simulate its operation - make a jumper for 1st and 2nd gear.
    Since the errors disappear after unplugging the battery, the map in the petrol controller disperses. LPG or probe not set correctly.
    In the measuring blocks in the engine you will see how it increases in plus dose enrichment because it sees a lean mixture or no probe response to LPG.
  • #6 16639401
    heniek1821
    Rate: 8
    Gentlemen, yesterday I connected Vag again and it weakened me ...:
    16518 Lambda probe no voltage change (page 1 sensor 1) no accessories / not related to the equipment
    16684 Random ignition loss no accessories / not related to hardware - sporadic error
    16686 No ignition cylinder 2 no hardware / not related to equipment sporadic error
    I already thought that after changing the coil, I have a problem with the loss of ignition because I haven't had this error for a long time.
  • #7 16639761
    sebap
    Help: 538
    Rate: 1082
    Did you change cables and spark plugs?
    What do you mean by writing
    How's the gas installation? What components of it?
    Did you follow the advice of your colleagues and did you only go to PB for some time?
  • #8 16641583
    heniek1821
    Rate: 8
    I checked the cables by spraying water at night, there was only a small, hardly visible sparks, the unscrewed candles also look ok.
    BRC installation. After clearing the error from yesterday the car drives normally without any faults but of course until. I drove the PB test for 20km on gas the probe appeared (when connected to the vag because the check is lit only after a few days driving when the error appears with a poor mixture), while there is no error on the PB.
  • #9 16641919
    grala1
    Help: 1495
    Rate: 5052
    You have incorrectly adjusted LPG or the reducer is not making.
    It is necessary to check whether the regulator maintains the set pressure and how to adjust the installation.
  • #10 16670370
    arekwij
    Help: 9
    Rate: 24
    At what mileage did you buy the car and how much had it "gone" on gas, did the previous owner do anything in the installation. Because from what you write, adequate regulation should suffice, but as e.g. the gas mileage is much greater than 100,000 km, perhaps regeneration of the reducer would also be useful.
  • #11 16670479
    Toporek98
    Rate: 18
    I wonder if according to the previous owner properly serviced it and whether according to serviced. BRC is a good installation, it is good not to blame the matter at first and set the service as an adjustment. If lambda has errors, I bet on a poor mixture and maybe the lpg regulation alone is enough.
  • #12 16782087
    heniek1821
    Rate: 8
    I come back to the topic after a long break. After cleaning the gas injector (infiltration of the cleaning agent) there was improvement for some time, the jerking stopped, but the combustion, probe error and rattling from the pipe still remained. The day before yesterday, the problem with jerks came back and the errors were joined by a random ignition failure + ignition loss on the second cylinder. Yesterday I went to a decent gas burner who took out my gas injection rail for washing in an ultrasonic bath and cleared the errors. Returning home on the PB there was no jerking, burning on the road at the level of 13.5 l. After driving 50km I set up to connect the computer and check what is going on (although the check did not pop up). And I saw errors of course the probe: 16518, 16521, 17536. I don't know whether to change the probe or not? The incorrect result of the probe can also be influenced by the flow and the damper. How to exclude their failure?
  • #13 16782240
    sebap
    Help: 538
    Rate: 1082
    It is possible that the reducer fails and the LPG map is worth a look. Go to some BRC magician.
  • #14 16782289
    heniek1821
    Rate: 8
    Well, today, they will check everything for me as they will mount the strip after washing, but here is the problem that on the PB itself at the longer route crashes for me these probe errors. The question now is how to check whether the flow or damper does not cause these errors
  • #15 16782300
    grala1
    Help: 1495
    Rate: 5052
    If you have cleared errors before and after driving on PB shows no voltage changes on the probe, I would rather suspect a damaged probe, unless it is mega poor.
    Show what the probe shows at idle and when booting, the same with the flow meter.
The discussion revolves around a VW Bora 2.0 8V AQY experiencing significant issues, including high fuel consumption (17-18 liters/100km), uneven engine operation, and error codes related to the lambda sensor and ignition. Users suggest checking the lambda probe's functionality, adjusting the LPG system, and ensuring proper installation and maintenance of the gas components. The presence of multiple error codes indicates potential issues with the ignition system and fuel mixture. Recommendations include cleaning the gas injectors, verifying the LPG regulator's pressure, and considering the replacement of the lambda probe if errors persist. The discussion highlights the importance of proper gas system calibration and regular maintenance to resolve these issues.
TL;DR: VW Bora 2.0 8V on LPG showing 17–18 L/100 km, rough idle, and lambda faults is often a tuning/pressure issue—“LPG incorrectly adjusted or the reducer is not making.” [Elektroda, grala1, post #16641919]
Why it matters:** This FAQ helps Bora/AQY owners diagnose uneven running, high fuel burn, and O2-code chaos, especially after LPG installs.
How do I quickly tell if LPG tuning is my main problem?
Clear adaptations, drive only on petrol for a few days, and re-scan. If lambda faults appear mostly on LPG, the map or reducer is off. The expert note: “You have incorrectly adjusted LPG or the reducer is not making.” Check regulator pressure and recalibrate the LPG ECU. [Elektroda, grala1, post #16641919]
Why does my gauge stay at 90°C while VAG-COM shows 100+°C?
The Bora’s cluster holds 90°C across a broad true range, roughly 70–105°C. Compare the dash reading with ECU data. Verify both fan speeds: turning on AC should start both fans in first gear. Faulty first‑gear resistors can let temperature creep up. [Elektroda, grala1, post #16635059]
What does code 17536 (system too lean) mean on AQY with LPG?
It indicates the ECU adds fuel long‑term to correct a lean mix. On LPG this often points to bad calibration or low reducer pressure. Lean running also triggers O2 non‑switching codes and rough idle. “LPG lambda probe does not work and the petrol map runs down.” [Elektroda, grala1, post #16634660]
Misfire on cylinder 2 after new coil—what next?
Swap or test plugs and leads, then scan again. The thread shows random misfire plus cylinder 2 misfire persisted despite a new coil. Inspect LPG injector flow balance and wiring, since uneven gas delivery can mimic ignition faults. [Elektroda, heniek1821, post #16639401]
How do I reset fuel trims (adaptations) on this engine?
Three steps: 1. In Engine module, Adaptation, Channel 00, “Save” to clear learned values. 2. Drive on petrol to relearn baseline. 3. Only then enable LPG and retune. This isolates LPG effects from petrol trims. [Elektroda, grala1, post #16634660]
What is the LPG reducer (vaporizer), and why does it matter?
The reducer drops tank pressure and vaporizes LPG at a stable set pressure. If it drifts low or unstable, the engine runs lean, raising 17536 and O2 errors. A weak reducer demands pressure checks, adjustment, or overhaul. [Elektroda, grala1, post #16641919]
Could dirty LPG injectors cause jerking and high consumption?
Yes. Cleaning briefly cured jerking in the thread, but codes and high burn persisted. The shop used ultrasonic cleaning on the rail. If symptoms return, recalibrate after cleaning and verify trims on petrol first. [Elektroda, heniek1821, post #16782087]
What is a lambda (O2) probe, and when should I replace it?
The lambda probe measures oxygen to guide fueling. If, after clearing codes and driving only on petrol, you still see “no voltage change,” the probe may be faulty unless the mix is extremely lean. Test at idle and during rev blips. [Elektroda, grala1, post #16782300]
My Bora runs fine on petrol but throws O2 codes on LPG—why?
That pattern points to LPG calibration or hardware. Petrol map looks clean; switching to LPG triggers 16518 and lean codes after a short drive. Check LPG pressure stability and re‑map; confirm O2 switching on both fuels. [Elektroda, heniek1821, post #16641583]
What’s the expected fuel use on petrol vs LPG after fixes?
In the thread, petrol consumption dropped to about 13.5 L/100 km after injector service. LPG had been 17–18 L/100 km during faults. After proper calibration and reducer health, LPG should approach petrol’s baseline plus typical LPG overhead. [Elektroda, heniek1821, post #16782087]
Edge case: why did lambda and lean codes return after 50 km on petrol?
The poster saw 16518, 16521, and 17536 again after ~50 km on PB. That suggests the O2 sensor may be weak, or airflow/throttle issues skew readings. Verify O2 waveform and MAF outputs before condemning parts. [Elektroda, heniek1821, post #16782087]
How do I check if the cooling fans’ first speed works?
Turn on the AC; both fans should start in first gear immediately. If not, test the radiator thermal switch by bridging first and second speed circuits. Failed resistors are common and allow heat soak. [Elektroda, grala1, post #16635059]
What is the MAF (flow meter), and can it trigger lambda faults?
The MAF measures intake air; a skewed MAF causes incorrect fueling and apparent O2 faults. Compare MAF readings at idle and during throttle blips alongside lambda response to confirm behavior before replacing parts. [Elektroda, grala1, post #16782300]
Should I avoid LPG temporarily during diagnosis?
Yes. Drive only on petrol for a few days. This isolates whether faults stem from LPG mapping or hardware. One advisor explicitly recommended pausing LPG to validate the diagnosis path. [Elektroda, g107r, post #16634850]
When is reducer overhaul justified?
If mileage on LPG is very high (e.g., >100,000 km) or pressure cannot hold setpoint, regeneration is sensible. Users reported better results after reducer service when calibration alone failed. [Elektroda, arekwij, post #16670370]
Is BRC hardware itself the problem here?
BRC is generally solid. The thread suggests proper service and calibration first, as lean mixture and O2 errors often reflect tuning. “BRC is a good installation… set the service as an adjustment.” [Elektroda, Toporek98, post #16670479]
