Volvo FH2012: Webasto Air Top 2000 ST Blocked - Unlocking Controller & Clearing Air Intake
Kaspian10 8154 2
  • #1 16200140
    Kaspian10
    Level 4  
    I have a problem with webasto air top 2000 st I fired a dozen times and it blocked me now I do not want to start at all, how can I unlock the controller to start it, I will also add that the air intake was blocked
  • #2 16200324
    maher440
    Help: 9
    Rate: 170
    Older, that is 2000,2000s, I unlocked by unplugging and connecting the main power supply with the heating on, then turning off the webast, fastening the power supply and start. I'm not sure if the ST can be unlocked in this way.
  • #3 16200335
    serwis_gh
    Diesel injection systems specialist
    Help: 211
    Rate: 1238
    Same. You unplug the power plug and plug it back in.
