Mercedes Actros MP3 - Actros MP3 webasto does not respond to the switch
agtrek 27465 7
  • #1 16394502
    agtrek
    Rate: 50
    Actros MP3 webasto does not respond to the switch - as the topic turned off last night alone and today does not want to start, the LED on the switch does not light up and the webasto does not move. Both switches do not work, above the driver and above the bed. any help?, maybe someone had a similar problem? Please give me a hint where to look.
    _Megamax_
    Help: 29
    Rate: 131
    Connecting to a diagnostic computer will help.
    It is worth checking the power supply in the 9-pin connector, it is on the right pillar in the dashboard, from there the cable goes under the threshold pad to the back. Moisture often appears there etc.
    The switching signal first goes to the MSF from it to the GM and then to the heating controller.
    Check if you can turn on the timer with INS "clocks".
  • #3 16395205
    agtrek
    Rate: 50
    Hello, after pressing the webasto switch does not work, the light is off. From the switch you can enter the menu and set the timer, temperature, but the webasto still does not start at the set time, the battery was disconnected and did not help :(
  • #4 16397165
    _Megamax_
    Help: 29
    Rate: 131
    Well, unfortunately, as I wrote before. Diagnostics only.
    Without a computer, even a physical replacement will not start it.
    Unless replacement including driver.
  • #5 16397984
    agtrek
    Rate: 50
    It helped to unfasten the 9-pin connector, remove the fuse and unfasten the switch. Webasto is nice :)
  • #6 16398576
    Hart3
    Help: 100
    Rate: 479
    There was a heating blockage by disconnecting the power supply, a reset occurred. This procedure is effective when used for eberspacher but it does not work.
  • Webasto shuts off after 15 minutes unless ignition is fully on
    #7 16407176
    agtrek
    Rate: 50
    The topic is back. Webasto after the last unfastening of the 9-pin cube for one night worked, now it goes out after about 13-15 min. The inlet grilles hardly checked or clean is dismantled for certainty. One wonder is the fact that the webasto in the actros in continuous operation works on the 1st position of the ignition / radio and webast power supply, lights off /. And here the curiosity after setting the ignition key / lights on the board shine / webasto works and does not go out after 13-15 minutes. Do you have any ideas where to look :) what to check It's even about emergency help before the car goes to the site.
  • #8 20303603
    sinisafiraunovic
    Rate: 17
    A gde je osigurač za Webasto probao sam 9pin konektor i ne reaguje upali lampicu ali se ne pokreće
The discussion revolves around a malfunctioning Webasto heater in a Mercedes Actros MP3, which fails to respond to the switch and does not start. The user reports that the heater turned off unexpectedly and the LED indicator on the switch is unlit. Various troubleshooting steps are suggested, including connecting to a diagnostic computer, checking the power supply at the 9-pin connector, and ensuring the timer settings are correct. A follow-up indicates that disconnecting the 9-pin connector and removing the fuse temporarily resolved the issue, but the heater later shut off after 13-15 minutes of operation. Further suggestions include checking the inlet grilles and the fuse for the Webasto system.
