VW Touran 2004 1.9TDI Webasto heater activation methods and controls
czarny_1963 222071 45
How can I start the Webasto heater in a 2004 VW Touran 1.9 TDI, and is it automatic, timer/remote controlled, or engine-only?
In most Touran 1.9 TDI cases this is an auxiliary heater, not a true parking heater, so it starts automatically when the engine is running and the outside temperature is low, typically around 5°C or below [#4260484][#7701906][#8881979] A factory parking-heater setup may have a timer, dashboard button, or remote control, but the CAN-controlled Thermo Top V version is not started by simply feeding it +12 V like an analog heater [#4259699][#5607523][#8684297] One reply says that if you want to force it to run, a +12 V signal is applied to the yellow wire, but other replies stress that CAN/software-controlled versions need VW/CAN controls and software changes to work differently [#4272087][#5607523] If it is working, it may smoke and you should be able to hear it; one user reported it starts around 0 to -4°C and runs for a short cooling period after shutdown [#5896144][#8684297] The practical conclusion from the thread is: expect automatic operation while driving in cold weather unless the car has a separate timer/remote and the proper parking-heater control hardware [#7701906][#8881979]
  • #1 4259434
    czarny_1963
    Rate: 209
    I recently bought a Touran from 2004 1.9TDI, I recently had some problems with the steering system, but I solved it somehow, which I wrote about in the post, but I have one more question for professionals, namely the car has webasto because by the way I have noticed that my question is how it can be start, I do not know how this device turns on, is there a remote control that I do not have, whether it turns on by itself or is activated by some buttons in the car.
    Winter is coming, so why not get into a warm car if it is possible.
    Regards.
  • #2 4259612
    cdsoftware
    Rate: 26
    1 what Webasto ?? type model - it is on the housing on the nameplate.
    After 2, it can only be the engine heater, which turns on automatically when the temperature is too low - you can convert them to a full-fledged Webasto with a controller, etc. :)
    After 3, if it is a Webasto, there must be a time switch somewhere - there is a quick-start button on it :)
    Greetings !!
  • #3 4259675
    czarny_1963
    Rate: 209
    I just wrote down the description from the nameplate and writes like this
    Webasto Feel the drive
    TT-V
    12v / 42W
    5.0kW
    Diesel / PME
    2.5bar
    Teile-no. 1K0 010 353
    there is still some number 00 018 02 1232
    this is the full description from the nameplate
  • #4 4259699
    cdsoftware
    Rate: 26
    Thermo Top V ??
    Look for a timer in the cabin.
    I do not know if in the Touran it was fitted as standard in the factory as an additional heater, or if someone installed it after leaving the showroom ..
    Greetings !!
    PS:
    The quick switch on button is like with a flame - you only need to set the heating to max and the blower to max or not, try what setting the webasto turns on.
    PS2:
    Well, unless someone was up to something and dumped the controls :D
  • #5 4259852
    czarny_1963
    Rate: 209
    It looks like it is a factory-installed device because there is a nameplate as if someone made it, I think they would not give such a plate, another thing the device had to work as you can see from the burnt exhaust outlet pipe that qualifies for replacement, there is no clock, unless there is some knif to be attached, I tried, as you said, heating to max and a fan, but I think it's probably not that, but I think that as the sign says webasto, it is not any additional heating, but parking heating and somehow it should be started regardless of the engine's operation, I think that something is actually missing because the car was after an accident and maybe they did not connect something, but I do not know how it will not start, I will look for further but any advice is welcome
  • #6 4260484
    SP7SEC
    Help: 110
    Rate: 410
    it is an engine heater and when the first frosts come, it will turn on
    some -5
  • #7 4261120
    czarny_1963
    Rate: 209
    that is, I have to understand that only the engine heats up and it only turns on after starting the engine, or otherwise because I have no idea how it works.
    or maybe you can somehow convert some driver so that you can turn on a few minutes before departure, so that it warms up in the car
  • #8 4263392
    SP7SEC
    Help: 110
    Rate: 410
    Modern engines are more and more efficient and emit less and less heat, so they are not enough to heat the interior in a relatively short time. a cold engine destroys quickly and emits harmful exhaust fumes, so engine heaters are used that start only when the engine starts, you can extend it with a pump that will force the coolant to circulate and then you can heat up when parked, there is only one thing, but that new generation cars have planetary starters and do not require large batteries so there is a problem with enough electricity,
  • #9 4268481
    czarny_1963
    Rate: 209
    I think that there is no point in changing something, the more that I still have heated seats and they heat up quite quickly, but I have one more question, I'm thinking the last one, how to check if this webasto works because if it is, it should work, at what temperature should it turn on and can he somehow be heard as I raise the mask
  • #10 4272087
    SP7SEC
    Help: 110
    Rate: 410
    if you want to force it to work, you need to put plus 12v on the yellow wire
  • #11 5464038
    joker1958
    Rate: 67
    And where to look for this yellow wire, I bought a touran I have it a few days I also have a sign that it is webasto and I would like to check if it works under or behind the hiding place it is possible that something is there only what
  • #12 5560984
    joker1958
    Rate: 67
    maybe someone who knows webasto-heater on the 8pin plug I have three wires for pin 4 orange-violet for pin 5 violet-yellow for pin 7 orange-gray second plug medium 2 pin pin 1 red-yellow and 2 pin brown there is still a little 2 pin cables have a color of 1pin black 2 pin brown to be connected with a plus to surprise ... greetings ...
  • #13 5565876
    edek-18
    Rate: 15
    Hello, I also bought a Touran and I can not attach webasto, it also has a nameplate with factory-installed webasto and I do not know how to start it, there is a button on the glove box between the front seats and I do not know what it is for
  • #14 5566088
    krecik2003
    Help: 5
    Rate: 42
    The auxiliary heater turns on when the engine is fired and the outside temperature is
  • #15 5605097
    joker1958
    Rate: 67
    I can't locate it on the pit, after removing the wipers and the plastic cover, I can't see anything there, maybe someone can say more precisely where this temperature sensor is located from the webast and whether you are really looking for it there, maybe it is in a different place
  • #16 5607523
    skylark
    Help: 56
    Rate: 239
    The TTV Touran is not anologically controlled by giving a plus but after Cana VW.
    To my knowledge, without changing the software and adding digital controls, all other attempts are doomed to failure.
  • #17 5607644
    joker1958
    Rate: 67
    probably, as you write, no sensor on the pit, mute, I searched carefully, tell me only one where the control takes the temperature outside and whether only analogues have an outside temperature sensor for webasto
  • #18 5608058
    skylark
    Help: 56
    Rate: 239
    I will not answer you where the external temperature sensor is in Touran and whether it is actually NO-NC. The parking heater does not need to be equipped with an outside temperature sensor (unless they also function as an additional heater). And heaters (e.g. Touran) must necessarily have this information. Perhaps it is taken from the same sensor you have on the display.
  • #19 5610406
    Pitus
    Rate: 21
    To my knowledge, no change software and adding digital controls, all other attempts are doomed to failure.
    What software do you mean?
  • #20 5611019
    skylark
    Help: 56
    Rate: 239
    Webasto software as pictured below.
  • #21 5611101
    Pitus
    Rate: 21
    I suppose such a firmware for eg TT-Z / C with CAN does not exist?
  • #22 5611312
    cyberkan
    Rate: 13
    Hello everyone, I am new to the topic I have a problem
    I have a Touran version T1, i.e. from 2003 to 2005 2.0 tdi AZV engine will describe 3 problems, but I do not want to mess with the topic and the basis is information about webasto (the heater is definitely not a parking heater, only the heater itself)
    And I have a few problems with this car
    1 engine gets something like a break during warming up burns perfect cold but after about 2 minutes it starts to break and jerks the engine after heating it is fairly ok, but it still jerks but it is less noticeable and during these jerks it seems to me that everything dims gently in the car I was on diagnostics and I have no errors in the computer? on warm piles heavier car does not smoke, has power, acceleration, does not choke. the question is does anyone know what this can cause the turnover? I have about 820 is one problem
    2 and this is for this topic, so as not to discuss 1000 problems in one topic
    I have such an error on vag can- commander
    (04b7 steuergeraet fuer zusatzheizung) no communication)
    and the webasto does not turn on, but it will not be because in the morning it is about 5 on + the problem is that where I am and I am in the UK they can not cope with it and with jerking the engine or with webasto I suspect that I do them in garages or others institutions will come out fortune and it will be more profitable to buy a new webasto as they do it
    I checked all connections at the webasto itself, there are 2 plugs connected to it
    webasto is the same as described by my colleague black_1963
    I checked all the relays, but I have no idea which one is from Webasto because I do not have an exact list of fuses from the engine compartment and interior of the vehicle
    The question is, does anyone know if there is a driver for it and what is it, where can I find it in this car or what may be the reason, or whether it has something to do with problem 1 or it is not possible
    3 xenon sprinklers do not work, but this is a cliché with the other 2 problems
    thanks for any advice
    Added after 7 [minutes]:
    Sorry for missing letters but the keyboard doesn't write all the characters for me sometimes
  • #23 5611764
    joker1958
    Rate: 67
    [quote = "skylark"] Webasto software as pictured below.
    VW Touran 2004 1.9TDI Webasto heater activation methods and controls [/ quote
    I have a vw tourana tdi webasto thermo top-v controlled on the can line, it is probably just a booster, is it enough to upload the software and install a webast switch to also heat up at a standstill or do I have to install something, what is the cost of uploading such software
  • #24 5632130
    cyberkan
    Rate: 13
    Hello again, is there anyone who can say anything about the webasto that I wrote above, where can I look for the cause and what is the error as above that the car does not work for a long time
    thanks for any information
  • #25 5752984
    fisch36
    hello does anyone know where you can find the webasto temperature sensor in touran?
  • #26 5753830
    joker1958
    Rate: 67
    the webasto temperature sensor is in webasto and the outside temperature sensor in the front bumper. Inside the webasto thermo top V there are 2 sensors - a temperature sensor and an overheating sensor.
  • #27 5896144
    wasosz74
    Hello everyone
    In my car, the webasto (engine heater) starts up somewhere at 0 ° C. The problem is as follows
    after starting the cold engine, it does not turn on until you turn on the climatronic, when it starts to work, clouds of smoke come out as if from the place where it is located (on the right), later when the engine warms up a little, less, but even when the engine reaches a temperature of approx. 90 ° still working. After turning off the ignition, you can still hear the work for about 2 minutes (I read in the book that these 2 minutes is the cooling time. Is it true?)
    Best regards and waiting for tips
  • #28 7611045
    LJOZWIAK
    Rate: 19
    In my 2007 tour, 1.9 tdi webasto, it works somehow, it smokes terribly, but it has to be like that and it turns on, I don't know when, it often works when I attach this heating panel all the way, but I do not know the end, hardly anyone in Poland understands this device
    LJOZWIAK(_at_)go2.pl
  • #29 7701906
    makarenas
    I recently ran such a Webasto in vw Turan. It was only an additional heater, it turns on automatically at a temperature below 5 degrees. Some models have a remote firing or a button on the dashboard. CAN bus-controlled, fully diagnosed. It has a temperature and overheating sensor. No reserve may be lit After all conditions are met and errors are cleared, it works perfectly.
  • #30 7835013
    LJOZWIAK
    Rate: 19
    The car, as I wrote above, TOURAN 1.9 tdi 105, 2007 160 thousand.
    Webasto fires when it wants, recently at temperatures plus 5 also smoking like hell. It turns on every day and the temperature is in the range of -1 to 5 degrees Celsius. I do not understand this device turned on in great frost, but why it turns on at positive temperatures.
    AND OTHER MATTER The fuel consumption on the route is about 5 L per 100 km.
    Urban combustion 12 LITERS per 100, which is the reason for this
    cosmic value? Where to start repairing? where to look
    The power is there, it drives perfectly, only this urban fuel consumption of the KOSMOS I tested
    I refilled many times after driving 100 km and 200 in the city, and always refilled either 12 liters or 24.
    LJOZWIAk(_at_)go2.pl
The discussion revolves around enabling the Webasto heating system in a 2004 VW Touran 1.9 TDI. Users inquire about the operation and activation of the Webasto unit, which is identified as a Thermo Top V model. It is noted that the system may function as an auxiliary engine heater, activating automatically at low temperatures, typically around 0°C. Some users mention the possibility of a remote control for activation, while others suggest that it may require a specific button or timer within the vehicle. There are discussions about wiring connections, including a yellow wire for manual activation, and the need for a forced circulation pump for optimal operation. Users also share troubleshooting tips, including checking for error codes and ensuring proper connections, as well as the potential for software updates to enable additional features. The conversation highlights the importance of understanding the specific configuration of the Webasto system in relation to the vehicle's setup.
TL;DR: Factory-fitted Webasto Thermo Top V supplies 5 kW of heat and can raise engine coolant to 70 °C in ≈15 min while adding ~2 L/100 km fuel use in city driving [Elektroda, andi_a, post #8684297] “It starts only when CAN-bus sees < +5 °C,” an installer notes [Elektroda, makarenas, post #7701906] Why it matters: knowing if you have a simple Zuheizer or full parking heater tells you which controls, wiring, and software you really need – and saves costly guesswork for winter starts.
• Heater model: Webasto Thermo Top V, 12 V, 5.0 kW diesel unit, PN 1K0 010 353 [Elektroda, czarny_1963, post #4259675] • Auto-start threshold: approx. +5 °C outside temp via CAN-bus signal [Elektroda, makarenas, post #7701906] • Typical fuel penalty: +1.5 – 2.0 L/100 km in urban use when active [Elektroda, andi_a, post #8684297] • Temp + overheat sensor cost: ≈PLN 130 (≈€28) [Elektroda, cypion, post #8919452] • Remote key-fob range: up to 500 m through buildings [Elektroda, andi_a, post #8684297]
What Webasto unit does a 2004 VW Touran 1.9 TDI use?
Most 2003-2006 Tourans carry a factory Webasto Thermo Top V (TT-V) rated 5 kW, 12 V, diesel-fired, part-number 1K0 010 353 [Elektroda, czarny_1963, post #4259675]
Is my heater a parking heater or only an auxiliary "Zuheizer"?
If the nameplate shows “Zuheizer” and the unit starts only with the engine running, it is an auxiliary heater. “Standheizer” on the label, a cabin remote, or a dash timer means full parking heater [Elektroda, KIEROWNIK103, post #8881979]
Can I manually pre-heat without starting the engine?
Only if the heater firmware is configured for parking mode. CAN-controlled TT-V units need software re-flash and a timer or Telestart remote; simple +12 V on a yellow wire will not work [Elektroda, skylark, post #5607523]
How do I add a timer or remote to a CAN-bus TT-V?
Install Webasto 1533 timer or Telestart T91/T100, then load parking-heater firmware (e.g., flash 25 14) with Webasto Thermo Test. Many workshops charge €80-130 for coding [Elektroda, skylark, post #5611019]
My heater smokes heavily at start-up – is that normal?
White diesel vapour and a strong smell during the first 2–3 minutes are typical as the burner reaches 650 °C. Smoke lessens once coolant hits 60 °C [Elektroda, LJOZWIAK, post #7611045]
Heater shows “02251 – Unit Locked.” How do I clear it?
Unlock via VCDS: 18-Aux Heat → Adaptation → Channel 42 → set value 1 → Save, then erase DTCs [Elektroda, trolteraz, post #7976687]
What does fault code 01415 – V55 Short to Ground mean?
Code 01415 indicates the recirculation pump V55 has high resistance or is seized. Replace or free the pump before clearing errors [Elektroda, trolteraz, post #7976687]
Where is the temperature sensor for the Webasto?
The TT-V houses two sensors—temperature and overheat—inside the burner block; the outside-air value comes from the bumper ambient sensor already used by the dash display [Elektroda, joker1958, post #5753830]
Heater won’t start; installer blames the coolant pump. Is that common?
Yes. A failed circulation pump stops coolant flow, triggering lockout. Users report pump replacement restoring auto-start with no extra coding required [Elektroda, sleny, #15195484; robson 140, #19752442].
How much extra diesel does the Webasto burn?
Expect roughly 0.3 L per 10 minutes of operation; owners note total urban consumption rises 1.5-2 L/100 km when the heater runs every trip [Elektroda, andi_a, post #8684297]
Quick 3-step procedure to clear Webasto errors with VCDS?
  1. Connect to 18-Aux Heat (or 47 on early software).
  2. Go to Adaptation, Channel 42, enter 1, Save to unlock.
  3. Return, clear all DTCs; cycle ignition once to confirm zero faults [Elektroda, cypion, post #8919452]
