[Solved] AVT DMX512 USB Controller: How to Install Drivers for Compatibility with Freestyler Program
Epix 17262 3
  • #1 16200555
    Epix
    Hello, I have a small problem because I am green in usb drivers. I bought the AVT DMX512 USB driver quite a long time ago I didn't get any disc with it but I found drivers but how can someone explain to me how to install them properly so that they work with the freestyler program in advance thanks ;)
  • #2 16200636
  • #3 16200641
    djlukas
    Help: 94
    Rate: 266
    From this page, download and install the appropriate driver for your system.
    http://www.ftdichip.com/Drivers/VCP.htm
    In the Freestyle program, use the "Enttec Open DMX USB" driver settings
    Ps. A colleague above warned me :D
  • Select Enttec Open DMX USB in FreeStyler
    #4 16208648
    TeamTrio
    I have this converter right now. The manufacturer provided him with a driver and software board.
    I use it under the program as the boys wrote FreeStyler above. After installing you enter Setup. You will see 2 headings, one from the settings and the choice of the converter and the other from the fixture. You choose the first one and you are looking for a driver called '' Enttec Open DMX USB ''. Once accepted, the red LED on the device should flash.
    You know what you connect behind the devices, you search in the program, if there are none there are 2 options. Either a familiar fixture will do for you or you can buy it on the Freestyler website. You add as many devices as you have and you can go ahead. If you have questions, write, I am happy to help.
    best regards
