- WinFast TV2000 XP Windows 10 Drivers: PS2 Console Connection & Multimedia Controller Issue
gooby120 11886 3
  • #1 16627564
    gooby120
    Well, I have a problem with the above-mentioned tv card. In the device manager it says that some "Multimedia Controller" is connected but I can't find a working driver for it. I was looking for other forums and found that you can do it manually, i.e. extract the drivers through winrar and stuff, but in my case it did not work and the manufacturer does not have any drivers for this card.
    Mainly I mean connecting the PS2 console to the computer.
  • #3 16628020
    Kasek21
    Help: 4981
    Rate: 3547
    You will not find drivers for this card!
  • #4 17049075
    Polonia.Minior
    Hello all. This is my first post. I know that several months have passed, but no one has yet provided a solution to the problem.
    There is a way to install WinFast on Windows 10. Please perform the installation as for Windows 8 / 8.1. Link to the thread: https://www.elektroda.pl/rtvforum/topic2370669.html. Just in case the link stops working:
    1. Download drivers in the form of an .exe file for Windows 7 (depending on your version, 32-bit or 64-bit);
    2. Unpack them (eg with 7-zip);
    3. Enter the device manager (go to This Computer, then on the empty PPM field and go to Properties. Then on the left side of the window there will be the device manager option);
    4. The device should be listed as "other device"> "multimedia video controller". Double-click on them with LMB and go to the drivers tab;
    5. Click "Update Driver" and then "Browse my computer ...";
    6. On the right side, click "Browse ..." and select the folder Drivers from the unpacked installer. Remember that the "Include subfolders" option should be selected. Then we go "further".
    7. A "WinFast TV2000 XP Expert (FM1216MK3) driver has been successfully installed" message.
    8. Finally, WinFast PVR2 for Windows 7 must be installed.
    After all this, the card should work fine except for sound adjustments. I also noticed that we have doubled audio when recording, although everything is fine after opening the video. Checked on Windows 10 Education version 1709 64 bit.
    Best regards!
    UPDATE:
    I have successfully fixed the sound issue. Change the sound settings. Below I am attaching a screenshot of the settings: - WinFast TV2000 XP Windows 10 Drivers: PS2 Console Connection & Multimedia Controller Issue
