VW Golf V 1.9 TDI: Error P0670 Glow Plug Relay, Electrical Fault - Autocom Diagnosis, 0.9 Ohm
patryk44gks 18165 10
Why am I getting P0670 glow plug module electrical fault on a VW Golf V 1.9 TDI, and where should I look first?
The fault was caused by a 50A fuse being installed in the wrong place, so the glow plug module had no proper power supply; putting the fuse in the correct position fixed the problem [#16224160] Before that, the thick supply wire to the module had no +12 V during the circuit test, even though the relay pin had 12 V with ignition on [#16222449][#16224160] The glow plug heating module was identified as the unit under the fuse box in the engine compartment, not just the relays above the driver’s legs [#16206389] A likely diagnosis path is to check the fuse, power supply, and wiring between the module and the glow plugs if the relay clicks but no voltage reaches the plugs [#16206242][#16222449]
  • #1 16205313
    patryk44gks
    Help: 11
    Rate: 74
    Hello, today I have connected the interface with the autocom program.
    He found an error P0670 - Module no. 1 of the auxiliary candle, electrical fault, permanent.
    I checked the candles and they all have 0.9Ohm, they are functional.
    I suspect the glow plug relay. Just where is he?
    Above the driver's legs
    I will check the voltage on the plugs tomorrow after disconnecting the engine temperature sensor
  • #2 16205937
    patryk44gks
    Help: 11
    Rate: 74
    On the autocom, he gives the temperature well on two liquid sensors.
    I also did a candle heating test and the switch seems to be ticking but on the plugs the voltage does not appear except for a constant 0.5v
    Maybe the contacts burned out in the relay.
    He'll measure it with a meter and take it apart.
  • #3 16206242
    grala1
    VAG group specialist
    Help: 1496
    Rate: 5057
    Maybe a contact on the relay, maybe a break in the circuit between the relay and the candles or no power supply to the working contact, i.e. there is no voltage on the relay so there is nothing to give.
    Write to others where this relay is.
    Give me a picture of the relay.
    There should probably be a relay there which supplies each candle separately, so there is no power supply.
  • #4 16206389
    patryk44gks
    Help: 11
    Rate: 74
    Well, I checked by autocom candle heating fast and slow heating and two relays are above the driver's legs depending on which mode I choose.
    Access to them is after removing the glove box under the steering wheel.
    But they seem to be in working order. And secondly, there is an error in the candle heating module, which means that it is the one under the fuse box under the hood. I will buy a new one and see it
  • #5 16222449
    patryk44gks
    Help: 11
    Rate: 74
    So that's how I bought this relay today and replaced it but it didn't work, I still get the same error.
    I checked two relays for heating candles and they are both functional. And on the pin supplying the relay there is voltage after turning the ignition switch 12v.
    Where to look further ??
    I checked all fuses with the meter and they are ok in the box under the hood and in the cabin.
  • #6 16224160
    patryk44gks
    Help: 11
    Rate: 74
    I also checked the wiring harness from the module for the fuse box today and it is functional. But there is no +12 on the thick cable to the module when calling the circuit test through the interface
    Added after 1 [hours] 7 [minutes]:
    Finally a problem has been solved.
    So I'll write maybe someone will use it.
    The culprit was a 50A fuse stuck by someone in the wrong place
  • #7 16254964
    patryk44gks
    Help: 11
    Rate: 74
    I have another problem about glow plugs so I continue this topic.
    So after replacing this module and putting the fuse in the right place, the system worked, the candles were in good working order.
    But for me in vw golf v 1.9tdi bls there are 5v glow plugs from what I know.
    And when I measured the voltage on the candle pipe after turning the key was 12v Should it be like this or is something damaged?
    Because yesterday I connected the interface and there were 3 errors regarding the 2,3,4 glow plug and after I measure the resistance meter it actually appears that they are burnt.
    And which company of new candles do you recommend NGK, BOSCH, BERU?
  • #8 16255169
    grala1
    Help: 1496
    Rate: 5057
    I recommend NGK.
    You go to the store and choose candles for the engine model.
    Open the old relay and show its electronics from the inside.
  • #9 16255325
    patryk44gks
    Help: 11
    Rate: 74
    NO I know that they match the engine it is obvious they are 5v
    And the module was chosen based on the old one.
    And that's why I was surprised that candles were damaged like tools 3, one is working.
  • #10 16255369
    grala1
    Help: 1496
    Rate: 5057
    Can you show the center of the old relay?
  • #11 16255551
    patryk44gks
    Help: 11
    Rate: 74
    And what do you need the interior of the module for ??
The discussion revolves around diagnosing an electrical fault in a VW Golf V 1.9 TDI, specifically error code P0670 related to the glow plug relay. The user initially checked the glow plugs, which showed a resistance of 0.9 Ohm, indicating they were functional. Subsequent tests revealed a lack of voltage at the plugs, leading to suspicions about the relay. After identifying the location of the relays above the driver's legs and checking their functionality, the user replaced the glow plug relay but continued to receive the same error. Further investigation revealed a 50A fuse incorrectly placed, which was the root cause of the issue. After correcting the fuse placement, the system functioned properly, although the user noted that the glow plugs should be 5V, while they measured 12V at the glow plug pipe. The user also inquired about recommendations for replacement glow plugs, considering brands like NGK, BOSCH, and BERU.
