vw t4 2.5 TDI - The glow plug indicator does not come on, the engine does not bu
miś913 13431 6
    miś913
    Rate: 17
    Hello. I just solved a problem in my Caravelka 2.5 TDI. The problem was this kind, I turn the key and the lights are on as always BUT !!!! this is important, in addition to the glow plug indicator light. I turn the key, the engine spins but does not start. The culprit is the voltage relay 109, or rather cold solder, after soldering the car, it's nice. The Germans write that these relays are known to have this problem. I am giving the page for this problem, maybe I will help someone.
    http://www.t4-wiki.de/wiki/Relais_J317_(Spannungsversorgung_Klemme_30)
    Moderated By T5:
    We appreciate that you provided a solution to the problem, your topic may be helpful to others. We award "He helped".
  • #2 16729483
    spinacz
    Help: 1206
    Rate: 2659
    The problem and solution known for years.
  • #3 16729532
    miś913
    Rate: 17
    Sure, only after three days of flipping our pages, it wasn't until the helmuts that I found a solution.
  • #4 16729555
    spinacz
    Help: 1206
    Rate: 2659
    You were poorly looking.
  • #5 16729560
    miś913
    Rate: 17
    Or maybe some link to the topic that I did not find?
  • #6 16729580
    spinacz
    Help: 1206
    Rate: 2659
    There is a lot of topics on 109 when it does not start and there is no candle light.
  • #7 16729638
    miś913
    Rate: 17
    A clear subject is given, clear symptoms and a clear cause, I will not idle discuss and clutter the topic.
The discussion revolves around a starting issue with a VW T4 2.5 TDI, where the glow plug indicator does not illuminate, preventing the engine from starting despite the ignition lights being on. The problem was identified as a faulty voltage relay (Relay 109) due to cold soldering. After re-soldering the relay, the vehicle started successfully. Participants noted that this issue is well-documented among VW T4 owners, with many discussions available on the topic.
