[Solved] Mixer for 6 Headphones + Microphone Communication: Budget Options (PLN 300/1000) for Music Bands
Rogal123456 6714 9
How can a band connect six wired headphones and a talkback microphone so everyone can hear the microphone without sending it to the main speakers?
Use a wired headphone amplifier fed from an AUX output of the Yamaha mixer, rather than buying another complete mixer. Connect the talkback microphone to a spare mixer input, route that channel only to the AUX bus used for monitoring, and do not send it to the main mix, so everyone hears it in their headphones. The Behringer HA8000 can distribute the signal to eight headphones, but it cannot accept a microphone directly because it has no microphone preamp; connect it to the mixer with a cable, or place an external preamp/small mixer before it. [#16210158] [#16216187] A headphone amplifier with individual level/EQ control for each channel, such as the ART 6 Pro mentioned in the thread, may be preferable if musicians need separate headphone adjustments. [#16216873] [#16217166]
  • Request for six headphone monitoring and microphone communication mixer
    #1 16208349
    Rogal123456
    Hello, if the topic is in the wrong section, please move it. It's the first time I'm getting used to it.
    I urgently need help because I don't know how to fix it. Namely, together with the music team, we want to buy a mixer that will allow us to plug in 6 headphones + a microphone so that we can communicate with each other (and not shout over the stage).
    A lot of bands do just this (listening in headphones) I'm already bothering with listening in the loudspeakers enough that you have to carry 2x loudspeakers, there is nowhere to spread it again, because it's such a tight place, and the second thing it's hard to set up these speakers so that everyone looks nice they heard.
    We have a Mixer with the band (connect microphones and holistic devices) -----> Power Mixer (only front speakers) and an echo camera
    Now we need a good listening mixer, but which one? In order not to be overpriced, something from PLN 300/1000.
    And the technique of how to connect it in general. If I connect the microphone, everyone will hear me in the headphones?
    I am waiting for a reply, best regards
  • Tablet-controlled mixers provide separate AUX headphone mixes
    #2 16208441
    adambyw
    Moderator of Acoustics
    Help: 1120
    Rate: 829
    Headphone auditions are most often performed on wireless systems. And it costs from about PLN 700 for a system for one person. This can be done at lower cost with headphone amplifiers, but you will be plugged in with cables.
    How would you give the mixer models you already have and how many inlets you use, it would be better to advise something.
    Now tablet-controlled digital mixers are becoming more and more popular. They often have a relatively large number of AUX outputs, so each of you could achieve what you need while listening to your headphones. Plus one microphone channel would be dedicated to the talkback microphone if you need one. Only here your budget will increase to about PLN 2,000 (I think about RCF M18, Soundcraft UI16 or behringer XR16), but you will be able to give up the mixers you are using now. In addition, often such mixers have a simulation of guitar heads and packs, so that a bassist or guitarist could give up the amplifier.
  • #3 16208555
    Rogal123456
    POWERMIXER LDM SMX-11 + Yamaha MG16 / 6FX mixer
    Yamaha is pretty much busy. This includes 3 x vocal mics 2/3 mics for drums / etc ipt.
    I think wired (not wireless) can be .. How does it look affordable etc.
  • #4 16210158
    adambyw
    Help: 1120
    Rate: 829
    If you have one microphone input free, plug in the microphone there, do not send it in total, only for listening via the aux bus.
    Wired listening is the cost of a headphone amplifier and headphones. Here you have it multitest of such amplifiers, look at your needs and find prices. You will not pay more than PLN 1400 for a fancy one.
    Plus, of course, headphones and cables.
  • #5 16211638
    Rogal123456
    What do you think about the behringer-ha8000-8-channel-headphone-amplifier ? Could you connect a microphone to this amplifier so that everyone could hear it in the headphones?
    And the connection of the headphone amplifier looks like that from Yamaha I connect the channel with a cable to this amplifier>? I do not deal with it professionally, and as you know, the equipment can be damaged.
    3.1.18. Do not send links that will cease to be active after some time. This will make the discussion meaningless.
    Adamiv
    adambyw
    Help: 1120
    Rate: 829
    Rogal123456 wrote:
    What do you think of behringer-ha8000-8
    I don't really like this brand. But this is my private ale.
    You can't connect a microphone directly because it doesn't have a mic preamp. You won't find such an amplifier with a preamplifier. But you can always connect via an external preamp or a small mixer.
    Aside from the mismatch of levels, it will be the way you want.
    Yes.
    DjMapet
    Help: 2137
    Rate: 1718
    However, I suggest you get a headphone amplifier with the possibility of correcting each headphone channel.
    Best regards.
  • #9 16217347
    DjMapet
    Help: 2137
    Rate: 1718
    Another and cheaper one will be hard to buy, given the number of channels and functionality. I think it's cheaper at Thomann's.
    All in all, it is a matter to discuss with the musicians whether they will require listening with the possibility of individual correction.
    Best regards.
  • #10 17027352
    Rogal123456
    I bought a listening session. For this Shure se215 and greetings.
The discussion revolves around finding a budget-friendly mixer that can accommodate 6 headphones and a microphone for effective communication among band members during performances. Users suggest various solutions, including wired headphone amplifiers and digital mixers with multiple AUX outputs. Recommendations include the Behringer HA8000 headphone amplifier, which lacks a built-in mic preamp, necessitating an external preamp or small mixer for microphone integration. Other suggested models include RCF M18, Soundcraft UI16, and Behringer XR16, although these exceed the specified budget of PLN 300/1000. The importance of individual headphone channel correction is also highlighted, with users discussing the need for functionality and affordability in their equipment choices.
