Used Stereo Amplifier 2018 Recommendations: Connect to TV, 30m Room, 2 Speakers, ≤PLN 1,200
cypek238 5115 17
What used stereo amplifier or stereo receiver should I buy for a 30 m room with 2 speakers and TV connection, within about PLN 1,200?
For a 30 m room with only 2 speakers, look for a stereo amplifier/receiver rather than a home-theater receiver, and if you want to connect the TV by optical/Toslink, choose a model with a digital input [#17065543] The Denon PMA-1520 was suggested as a good option for that use case, especially when TV digital input matters [#17065543] A new Pioneer A-30 was also recommended as sounding very decent and priced around PLN 1,100 [#17059173] Another solid budget choice mentioned was the Yamaha R-S700, described as well-built and performing very well in stereo [#17066043] In general, a stereo receiver can be a sensible choice and does not have to sound worse than an amplifier [#17068698]
  • #1 17057194
    cypek238
    Hello, I am looking for a home stereo amplifier for 2018, I found nothing, all the forums I have read and I have not found anything, the equipment was supposed to play in a 30 m room, only 2 stereo speakers planned. Ampli connected to the TV of course what do you recommend
  • #2 17057616
    intenso
    Help: 480
    Rate: 617
    What does 2018 mean?
    Used from 2018?
  • #3 17057864
    cypek238
    Not used, but not a very old one, only one with hdmi and good sound nw I don't know, maybe denon is a good choice, e.g. avr1912
    Added after 57 [minutes]:
    Someone help?
  • #4 17058141
    intenso
    Help: 480
    Rate: 617
    3808 is definitely a better receiver.
    Why do you need a home theater receiver for stereo?
  • #5 17059023
    cypek238
    I just can't find any stereo amp, there are receivers everywhere. I found the onkyo tx8050 but I hesitate if it will be a good choice speakers will be tonsil maestro s ii 180
  • #6 17059173
    andrew54
    Help: 79
    Rate: 100
    As it should be only for stereo, I have recently listened to the Pioneer A-30, the new one, probably PLN 1100 and it sounded very decently.
  • #7 17059529
    cypek238
    Thank you for the answer, but I am not convinced by the pioneer, and if there are any suggestions
    Added after 12 [hours] 43 [minutes]:
    People, come on
  • #8 17065543
    damieen25
    Help: 9
    Rate: 15
    If you want better sound quality in stereo, I do not recommend the amplified kd, they fall out poorly. How do you want to connect the TV to the equipment because if via toslink you have such a possibility but with an amplifier that has a digital input. This makes me think of the Denon pma 1520 but do not confuse it with the AE series because it is a new series. This is a good and cool amplifier. What budget?
  • #9 17066043
    grzehu82
    Help: 49
    Rate: 39
    Look for the Yamaha R-S700, this is a budget receiver that is solidly built for this level, and in stereo it performs very well.
  • #10 17066379
    andrew54
    Help: 79
    Rate: 100
    The fact that the receivers sound worse is another stereotype, although there are many cases, which is actually the case, if the power amplifier is a solid construction based on transistors supported by an efficient power supply, the addition of a DD and DPL tuner and decoder does not really change the sound much, so if the cinema receiver has a Direct input, you can safely use it as a stereo amplifier. The long path of the signal proves the minus of the receivers, so it is necessary to check if there is a direct input so that the signal does not wander after a kilometer of paths and integrated circuits.
    I will not forget the test from 20 years ago in a well-known audiophile magazine where a Philips amplifier was tested, and in a few months a stereo receiver from the same manufacturer, it happened that both of them were at the workshop much later, what was my surprise as it turned out that the receiver was literally this amplifier only with a tuner added to the live, the same power amplifier, the same transformer, only a tuner board on the side, next to the sockets, and you know what? The amplifier fared very well and the receiver was bad ... then I stopped believing in listening tests and credibility in magazines for audio lovers
  • #11 17067954
    cypek238
    Thank you for the answers, recently I was looking for a lot, I read and caught my eye marantz pm6005 or denon pma720ae but nw is it worth packing in it, since the denon receivers have everything I need and I think that I will not lose so much on this sound.
  • #12 17068698
    grzehu82
    Help: 49
    Rate: 39
    You can buy a tuner in addition to the amplifier, a stereo receiver usually does not give way to its counterpart among amplifiers, while the KD receiver is a different shelf, for the same money, there is no start.
  • #13 17082551
    psylot
    I see that I used a kd receiver with stereo in mind and it came out of it, I thought that if a tall model it would do the job (Yamaha RX-V2700)
    My old Sony TA-FE600R amplifier sounds much better.
    I'm sorry that I connected to your topic this way, but I'm also looking for a set that will bring something more during listening.
  • #15 17115215
    cypek238
    Well, the receiver I bought a denon 2312 I am very happy with the sound, many settings and possibilities, but sometimes the Internet freezes
  • #16 17125603
    cypek238
    I have to replace the loudspeakers for better ones because these tonsil has little bass, which you suggest is used up to PLN 1,300
  • #17 17125629
    telecaster1951
    Help: 829
    Rate: 818
    Sure it is, but if we are talking about a stereo receiver. In the case of KD you have more channels, so more transistors, bigger heat sinks etc. It's easy to calculate that for the same money a KD receiver will be much worse than a stereo one.
    I have long stopped. One of them raised the Pylon Pearl to the skies and rode Tonsile with the ground, which were built on the same speakers, packed in the same package and with similar filtration. But he smeared Jujka and Wieszczeciński did not.
    Do you have little bass from them? Buy a subwoofer. When replacing the speakers, you will improve the treble and midrange. Basu not. Unless you buy some cheesy loudspeakers with boosted bass, but what for?
    The subwoofer will give you bass without spoiling the rest of the bandwidth.
    In 30 meters, you can already do something. For now, try repositioning the columns themselves. Start by checking to see if you have more bass in the corners of the room than at the listening position. If so, it may turn out that the speakers are fed up with bass, but their setting cuts it out. Sometimes even adding a subwoofer does not significantly improve the low bass, but it will add an unpleasant kick that drowns out the rest of the frequency range.
  • #18 17127526
    andrew54
    Help: 79
    Rate: 100
    Buddy, let's say I agree, but the mass of KD receivers has simply duplicated identical channels to be able to implement the soundtrack for movies, in other words give me a diagram of one channel and power supply, no matter if it's a KD receiver or stereo, I'll tell you how much it's worth. Very often the KD receiver will be better because it has luck calculated on more channels than stereo, I ignore the extremes of some low models, which on paper are 5 * 100Wa and 200W trafo. Let's skip the technics, pioneer and some yamaha receivers that had specially designed hybrids for additional channels and, funnily enough, they had different power than the fronts. It's terribly painful to repair and you have to wait a month for a delivery from China. A good KD receiver, when playing a direct signal only on stereo, will sound just as well as a stereo amplifier or stereo receiver.
    As for the tests in the magazines, I know that they are divided into several groups, the first case when the distributor provides, for example, an amplifier for testing and it includes an expensive alcohol attachment, less often an envelope or most often the annotation "if you like the sound please leave it", then a positive recommendation allows leave the equipment in the hands of the reviewer, then he stuffs it on the Allegro, the wolf is full and the sheep is whole. The second case, if the equipment is delivered without such an annotation or attachment, is condemned to a random test and cursory evaluation. The third category, if the distributor does not want to provide the equipment because there is no such model available or has to wait a long time, then the equipment is doomed to failure and the test is written without listening or after renting the equipment from the salon just to take photos. I will end by quoting the test of the stein-music de-3 demagnetizer of a device that cannot work in the well-known audiophile magazine "vinyl demagnetizer remains in my possession as a must-have". :)
The discussion revolves around recommendations for a home stereo amplifier suitable for a 30 m² room, with a budget of up to PLN 1,200. Users express difficulty in finding stereo amplifiers, noting a prevalence of receivers. Suggestions include the Denon AVR-1912, Onkyo TX-8050, Pioneer A-30, Denon PMA-1520, Yamaha R-S700, Marantz PM6005, and Denon PMA-720AE. The importance of direct inputs for optimal sound quality is emphasized, along with the potential benefits of using a subwoofer to enhance bass performance. Users also discuss the comparative sound quality of stereo amplifiers versus home theater receivers, with some advocating for the latter when equipped with direct inputs.
TL;DR: In a 30 m² room, start with speaker placement; "The subwoofer will give you bass without spoiling the rest." Chasing new speakers often boosts mids/treble, not bass; add a sub or reposition first. [Elektroda, telecaster1951, post #17125629]
Why it matters: This FAQ helps budget‑focused listeners connect TV and stereo in a 30 m² room and get the best sound for the money.
For stereo in a 30 m² room, is an AV receiver OK?
Yes, if it has a proper Direct or Pure Direct path. A solid AVR with strong power supply can rival an integrated amp. Long signal paths hurt some models, so the direct input matters. The idea that all receivers sound worse is a stereotype. Test with Direct engaged for fair comparison. [Elektroda, andrew54, post #17066379]
How do I connect my TV to a stereo amp without HDMI?
Use your TV’s optical output and an amp with a digital input.
  1. Check the TV’s optical (Toslink) out and set audio to PCM stereo.
  2. Choose an amp with optical input, or add a small DAC.
  3. Connect Toslink from TV to the amp’s optical input and select that input. This keeps the chain simple and reliable. [Elektroda, damieen25, post #17065543]
Is Yamaha R-S700 a solid budget pick for stereo?
Yes, it is a well-built stereo receiver for the price. It performs very well in stereo use. Its straightforward design supports dependable daily listening. Consider it among value options for music‑first setups. [Elektroda, grzehu82, post #17066043]
Is the Pioneer A‑30 worth it around PLN 1,100?
A listener auditioned the Pioneer A‑30 and liked its sound. The new price was about PLN 1,100 at the time. It delivered decent stereo quality for the money. If you prefer integrated amps, it belongs on your shortlist. [Elektroda, andrew54, post #17059173]
How does Denon AVR‑2312 perform for stereo and TV use?
A user moved to a Denon AVR‑2312 and was satisfied. They praised the sound, settings, and flexibility. An occasional internet freeze was noted. For TV plus music, it provided the needed features. [Elektroda, cypek238, post #17115215]
I get too little bass from Tonsil Maestro S II 180; what now?
First, try repositioning the speakers and the listening spot. Corners often boost bass, while some seats cancel lows. If bass stays light, add a subwoofer to extend the lows. “The subwoofer will give you bass without spoiling the rest of the bandwidth.” This improves bass without degrading mids and highs. [Elektroda, telecaster1951, post #17125629]
Should I replace speakers or add a subwoofer for more bass?
Replacing speakers often improves mids and treble more than bass. Bass‑boosted designs can add boom and mask detail. In a 30 m² room, a proper sub integrates better for deep bass. Repositioning can also unlock existing low‑end. Start with placement, then add a sub if needed. [Elektroda, telecaster1951, post #17125629]
Does “Pure Direct” on AV receivers help stereo sound?
Yes. Direct inputs bypass extra processing and shorten the path. This reduces losses from long signal chains and ICs. With a strong power stage, an AVR in Direct can match an integrated amp. Use Direct when comparing stereo performance. [Elektroda, andrew54, post #17066379]
Are magazine listening tests reliable for picking amps?
Treat them cautiously. One case showed a receiver that was the same amp plus a tuner board. The amp reviewed well, while the receiver scored poorly. The writer noted, “...stopped believing in listening tests and credibility in magazines for audio lovers.” Audition gear yourself when possible. [Elektroda, andrew54, post #17066379]
Is Yamaha RX‑V2700 good for stereo music?
One user tried the high‑tier RX‑V2700 for stereo and was disappointed. Their older Sony TA‑FE600R sounded much better to them. This shows execution matters more than badge or tier. Always compare against a known good stereo amp. [Elektroda, psylot, post #17082551]
Any compact all‑in‑one with DAC/CD that works?
Yes. A member uses the TEAC CR‑H700 successfully. It combines amplifier, CD, DAC, and network features in one box. This can clean up living‑room setups with fewer components. Consider it if you want simplicity. [Elektroda, gadi, post #17112097]
How should I place speakers in 30 m² to improve bass?
Test bass levels at corners versus your seat. If corners are fuller, you may sit in a bass null. Move speakers and seat to reduce cancellations. Keep some distance from walls to balance boom and depth. Adjust until lows sound even across the room. [Elektroda, telecaster1951, post #17125629]
Why do some AV receivers underperform despite big wattage claims?
Specs can mislead. Some low models claim 5×100 W with a 200 W transformer. That math fails under real loads. Added channels also raise cost and cooling needs. Prioritize real power supply capacity over brochure numbers. [Elektroda, andrew54, post #17127526]
Can I add a tuner if I choose an integrated amplifier?
Yes. Add an external tuner to any integrated amp with a free input. A stereo receiver usually doesn’t beat its amp counterpart in stereo. Home‑theater receivers are a different tier for the same money. Keep stereo priorities clear with separates if needed. [Elektroda, grzehu82, post #17068698]
Marantz PM6005 vs Denon PMA‑720AE: which to choose?
Both were shortlisted within this budget. Decide by inputs, DAC needs, and speaker synergy. Audition if possible and compare against an AVR using Direct mode. Pick the unit that matches your sources and room best. [Elektroda, cypek238, post #17067954]
