Seeking Speakers for Pioneer 502 Amplifier within PLN 500 Budget for 3x4m Room
TerFereTP 4029 15
Which speakers should I buy for a Pioneer A-502R amplifier in a 3x4 m room with a budget of up to PLN 500?
Do not buy the Altus 70 for PLN 350, because in this budget you can get clearly better used speakers [#16313297] A safe approach is to take your amplifier to the seller and listen before buying, since with used speakers the condition and sound matter more than the listing [#16313719][#16315097] From the models mentioned, the Braun LS70 was judged the best of the final three options and was said to look good and play correctly [#16314731] The Tonsil Disco 110 also has many positive opinions, but you should check the internal wiring and possibly replace thin cables if needed [#16314948] Other suggested options in your budget were Mildton 70/80, Tonsil Perfect 150, Tonsil Zg-30-C115, KEF Coda III, Sterling Point 7S, and Heco Cantaro 200 [#16313360][#16314206]
  • #1 16312670
    TerFereTP
    Hello, I am looking for speakers for the Pioneer 502 amplifier.
    Cost up to PLN 500
    Pop music, radio, movies
    Room about 3m by 4m
    I have an eye on altus 70 for PLN 350 in perfect condition from what the owner says
    I am a layman
    I am asking for your understanding
  • #2 16313297
    Daros1234
    Help: 9
    Hello, in the budget of PLN 500, I would not bother with Altus for this amount of money you can buy much better speakers.
  • #3 16313349
    TerFereTP
    In that case, the gazebos fall off ...
    What's next ??
  • #4 16313360
    Daros1234
    Help: 9
    Actually, they are supposed to be floorstanders?
    Added after 33 [minutes]:
    From the Polish speakers, I recommend the Mildtony 70 or 80, Tonsil Perfect 150 or Tonsil Zg-30-C115.
  • #5 16313460
    TerFereTP
    I am looking for floorstanding speakers
    although I was also wondering about the monitors ...
    I'm looking for an allegro because I want to buy some specific offers on the day?
  • Recommend Heco speakers with Harman Kardon or Denon amplifiers
    #6 16313472
    marcin55246
    Help: 53
    Rate: 168
    Look for the heco speakers, the harman kardon and denon amplifiers. Make your suggestions.
    Links to amplifiers, enter in Allegro.
    HK:
    6727812423
    6724558266
    6713513143
    6700346843
    6689802498
    Denon:
    DENON PMA-880R
    6730486691
    DENON PMA-860
    6704002118
    Denon PMA-735r
    6731186591
    I personally own the Harman Kardon PM650 Vxi amplifier and I am very pleased. HK-6500 Will also be good.
  • Recommended speaker listings for the Pioneer A502R amplifier
    #7 16313719
    grzehu82
    Help: 49
    Rate: 39
    The amplifier you have, I understand the Pioneer A502R. So that I would make an appointment with the sellers, take it with me and listen to the offers given below. Here are specific as close as possible:
    https://www.olx.pl/oferta/ Sprzedaż-kolumny-ta-pulsar-tar-550-e-CID99-IDjpMY0.html#15c1a0aa29
    possibly these: https://www.olx.pl/oferta/kolumny-magnat-super-brzmia-CID99-IDivedj.html#f2bcf7ecda
    If you believe the description, it can sound better than the above-mentioned correction boxes: http://allegro.pl/kolumny-podlogowe-na-na-norweskich-glosniki-seas-i6726840841.html#imglayer
    The rest are some strange inventions, or significantly out of budget. I don't think there are any new ones for the price, so I didn't even look for them.
  • Seeking help choosing nearby speakers under PLN 500
    #8 16313871
    TerFereTP
    Thanks for the help
    I haven't updated the city ..
    I live now in Chełmno, Kuyavian-Pomeranian Voivodeship
    I am happy to see other interesting offers
    Added after 36 [minutes]:
    https://www.olx.pl/i2/elektronika/mp3-sprzet-...%5D=500&search%5_st0filter_search%5_st0filter % 5D = used & search% 5Bdist% 5D = 50 & view = gallery
    These are relatively close speakers for up to PLN 500
    I am asking for help in choosing
  • #9 16314206
    grzehu82
    Help: 49
    Rate: 39
  • #10 16314544
    TerFereTP
  • #11 16314731
    Daros1234
    Help: 9
    Out of these three propositions, the best choice will be the Brauns ls70 that look great and will certainly play correctly. Personally, I would choose the Disco 110 as a fan of Polish equipment.
  • #12 16314871
    TerFereTP
    I am hesitating between these two disco 110 I have close to home tomorrow I will go listen to the latter, about 60 km
    I don't know which ones to take ....
    Which will have better bass?
  • #13 16314948
    Daros1234
    Help: 9
    Unfortunately, I did not have the opportunity to listen to these speakers. Tonsil Disco 110 has a lot of positive opinions about them, but if no one has done it yet, it would be useful to replace the cables, because knowing life there are very thin cables, just like in most tonsil loudspeakers from those years.
  • #14 16314952
    grzehu82
    Help: 49
    Rate: 39
    If you don't check, you won't find out ... In general, the size of the woofer, type, tuning, crossover, room and others have an impact on how we perceive bass sounds ... .
  • #15 16315044
    TerFereTP
    Disco 110 ZgC-60-8-537 for this model, the seller wants PLN 280
    On the other hand, there are offers for PLN 200 only on the net.
    I don't know if I won't overpay ..
    Do you haggle yet?
  • #16 16315097
    grzehu82
    Help: 49
    Rate: 39
    I can see that you are horny, but you probably haven't listened to anything else ... Better to spend PLN 50 on the road and gain some experience, and maybe even decent loudspeakers than to buy the first better speakers for a price that is not low compared to how they sound. If you could even watch on the net what each of the crossover cables and converters look like and compare them with the inside of the tonsil, you would have the answer what to buy.
The discussion revolves around finding suitable speakers for a Pioneer 502 amplifier within a budget of PLN 500, specifically for a 3x4m room, primarily for pop music, radio, and movies. The user initially considers the Altus 70 speakers but receives advice to explore better options. Recommendations include Polish brands such as Mildtony (70 and 80 models), Tonsil (Perfect 150, Zg-30-C115, Disco 110), and Heco speakers. Users suggest checking local listings for various models, including Braun LS 70, JBL LX700, and Magnat speakers. The conversation emphasizes the importance of listening to speakers before purchasing and considering factors like woofer size and cable quality for optimal sound performance.
