Suzuki Grand Vitara 1.9 ddis 2008: 4x4 Lights Blinking, Manual Control Box Issues
rusinp 16086 3
  • #1 16212404
    rusinp
    Rate: 46
    Hello, Suzuki Grand Vitara 1.9 ddis 2008, manual control box from blink drive, near the clipboard you can hear
    like some relay relay, the drive knob does not work in place N and sometimes does not react properly, including for 4h, lights up on a 4L board.
    Strange symptoms. I changed the oil in the box, the reducer and in the bridges, the fault was still not the same. There were several mechanics in the car, no errors were found in the box, there were two errors unknown 1436 and 2264.
    I am asking for some tips.
  • #2 16240229
    ziaja25
    Rate: 21
    Hello. To turn N from what I remember you had to turn the knob to the left and hold for a few seconds. Slack + press brake and clutch also sometimes helped. As it is on N and it is not disconnected, you can go but the indicator will flash. greetings
  • #3 16364165
    rusinp
    Rate: 46
    Hello, problem solved. Replacement cable from the reducer, after computer diagnostics, the fault has disappeared.
  • #4 18644031
    vitek2
    Rate: 25
    hello.rusinp I have a similar problem with the snapping of this relay in the driver from 4wd. do you associate what cable was damaged? greetings
