LG 42PT353A Plasma TV: Switch from Shop Mode to Home Mode, Factory Reset without Remote
Adamorod 4116 5
  • #1 16213393
    Adamorod
    Hello, I have a problem. I bought the LG 42PT353A plasma. It is set to shop mode, only RGB is displayed. How can you set it to home mode or restore factory settings? Unfortunately, I do not have a remote control / When I enter the settings, "factory reset" is grayed out, and unfortunately you can't hover over it to click. Can anyone tell me how to grasp it ??
  • #2 16213576
    majsterek
    Help: 79
    Rate: 70
    You can't probably get it without a remote control ... But a smartphone with Irda, or a universal or dedicated remote control should do the trick. After a factory reset you should be able to indicate where the TV will be used (store, home).
  • #3 16213578
    Adamorod
    I have a universal remote control but when I enter the settings, the "restore factory settings" option is grayed out and you can't click it? Can you restore the settings in some other way ??
  • #5 16213658
    Adamorod
    From what I see, I think I have the RGB-PC mode turned on, I can not switch it, I can not reset it, because in the settings it is not available, maybe someone knows how shortcuts on the buttons can be done?
  • #6 16213659
    lisek
    Service technician RTV
    Help: 6360
    Rate: 6891
    Without org. pilot forget about regulations and tr. service.
