[Solved] LG 32 LH500D Parental Lock: Forgot Password, Need Help - 3x Mute & Hotline Ineffective
Timmy2 14391 5
  • #1 17025034
    Timmy2
    Rate: 14
    LG's hotline did not help. 3 times Mute also not - help ...
  • #2 17025099
    DiZMar
    Help: 2891
    Rate: 6648
    If it was a parental lock with a password and the password of the general lock has not been changed, a factory reset with the password 0000 should help. If the password of the general lock has been changed, it remains to enter subsequent passwords. One is set up. Up to "only" 10,000 attempts are waiting for you. If you know one digit with its place, then max 1000 tries. Good luck.
    User manual here (over 50 MB). About blockade and reset, pages 55 and 56 (15 and 16 Polish).
  • #3 17025205
    Timmy2
    Rate: 14
    I knew it, I have the manual. Apparently there is a combination on the remote. Help.
  • #4 17025321
    LeDy
    Help: 1990
    Rate: 2937
    See 0000, 1234, 1111, 7777, 9999.
    This is 3x Mute you are doing properly?
  • #5 17029091
    Timmy2
    Rate: 14
    further nothing-massacre
    Added after 17 [hours] 7 [minutes]:
    nobody knows the solution. Save
  • #6 17030236
    Timmy2
    Rate: 14
    543 password attempted and hit. New password saved
