LG 32LD490-ZB: Accessing Service Mode, Sound System & UHF Band Adjustment, Service Pilot Info
ROMKOJ 5641 5
  • #1 9186712
    ROMKOJ
    Help: 46
    Rate: 26
    Hello, I have to reroute LG 32LD490-ZB BEKDLJP imported from England, but produced in Poland. It has only the I sound system and the UHF band. I tried to get into the service mode, but unfortunately it failed. Menu with remote control + keyboard menu held together for 10 seconds will not work. OK with the remote control + ok from the keyboard also does not work. Apparently a service pilot is needed, is this true?
  • #2 9191634
    makada
    Rate: 9
    To get to the service menu, a service pilot (though not necessarily a service one) is needed for 100%. You must look at the electrode because I used to read that other "universal" pilots can also be selected to the menu. And even a phone for symbiosis.
  • #3 9192430
    ROMKOJ
    Help: 46
    Rate: 26
    Maybe it will work, tomorrow a colleague is to provide a remote control which can be entered into the service mode
  • #4 9197840
    ROMKOJ
    Help: 46
    Rate: 26
    Hello, the remote is on, entering the service mode ok, the problem is with options. You can change it, but it does not help, it's still just the audio system. Finally, I can mount it to Rymi if it's okay with the client.
  • #5 9198812
    alvin
    Help: 93
    Rate: 44
    The customer is so picky and oriented? He will have a phony!
  • #6 9302795
    ROMKOJ
    Help: 46
    Rate: 26
    Hello, the problem is not resolved, the client has given up the tuning, in the service mode failed to find the DK sound system.
