Cooling System Indicator On/Off, Opel Astra G 1.6 16v: Causes, Diagnostics, and Prevention
Hegetz89 51903 2
  • #1 16214597
    Hegetz89
    Hello, I have a question and also a problem. When I turn on the ignition in the car, the cooling system indicator appears. When I start the car, the indicator goes out. This morning, when I was going to work, I started lighting up controls. (cooling system, helicopter, abs and airbags (the counter has hung up)) and the car went out in the middle of the road, then I left it for 3 hours and then I restarted it and the cooling system indicator appeared. What can it be related to, where to choose, what to check and how to avoid it would not shine? I am asking for great help, below I add a picture of the control and what I did not like while driving.
    Cooling System Indicator On/Off, Opel Astra G 1.6 16v: Causes, Diagnostics, and Prevention100_2736_..73.jpg (91.49 kB)You must be logged in to download this attachment.
    Cooling System Indicator On/Off, Opel Astra G 1.6 16v: Causes, Diagnostics, and Prevention16229743_1...7952_o.jpg (122.51 kB)You must be logged in to download this attachment.
  • #2 16215634
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3266
    Hegetz89 wrote:
    What can be associated with this, where to choose specifically
    https://www.elektroda.pl/rtvforum/topic1318793.html
    page 27
    Hegetz89 wrote:
    what to check
    Perform diagnostics
    take off the front bumper,
    carefully inspect all cooling module harness plugs
    Open the fan control module housing - pour out water from inside ...
    Check all cable connections from the battery clamp to the fuse box,
    and ground connection.
    Check the battery charging,
    Perform diagnostics ...
    https://www.elektroda.pl/rtvforum/topic573909.html
    https://www.elektroda.pl/rtvforum/topic1031611.html
    https://www.elektroda.pl/rtvforum/topic575543.html
    https://www.elektroda.pl/rtvforum/topic1786771.html
    https://www.elektroda.pl/rtvforum/topic816014.html
    For the future, read a little about your problem - before ...
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #3 19551101
    Kart
    Rate: 30
    It may be that all engine components are operational and it may rain the ECU
