Gas Furnace Exhaust Pipe: Types, Diameter, Length Options & Installation for Bathroom Renovation
sebaele22 14979 4
  • #1 16216239
    sebaele22
    Level 30  
    Rate: 513
    Hello, I would like to ask what pipe to use in the gas furnace? What diameter? Can the episode be of different lengths? I ask because I am renovating the bathroom, I have to lower the hole in the wall. The old pipe is flexible but already damaged so I do not know if it should overlap the collar in the oven or put it in the collar.
  • #2 16216276
    bro2004
    Level 30  
    Help: 160
    Rate: 637
    My glass ball does not see what kind of boiler you have mounted, make, model. Certainly acid-proof steel, rigid or flexible.
  • #3 16216296
    sebaele22
    Level 30  
    Rate: 513
    My stove is Ariston 24 CF, I know that stainless steel, but I do not know what size and whether the pipe must overlap the flange or the collar.
  • #4 16216317
    kot mirmur
    Help: 206
    Rate: 561
    Welcome, rather to the collar, measure its diameter and adjust the appropriate pipe.
  • #5 16216323
    ls_77
    Help: 500
    Rate: 947
    And I will say that the pipe is rather a collar.
    In gas-fired boilers, always pipe the chalice upwards.
    And it is best to look for instructions and there is always drawn how to put a chimney pipe and how to keep the minimum and maximum distances.
