Does not detect the graphics card - The computer does not detect the graphics ca
damianqo3 47577 15
Why does my PC not detect my AMD MSI HD7770 graphics card in Device Manager or BIOS, and how can I tell whether the card or the motherboard is at fault?
The card is most likely faulty or not being initialized by the PCI-E/BIOS, so the first checks are to reseat it, clean the contacts, reset the BIOS, and test the card in another PC while also testing another card in this PC [#16217284][#16219673] In a desktop, only one graphics adapter normally works at a time, and the BIOS decides whether the PCI-E card or the integrated GPU is used [#16217284] If the system boots on the integrated GPU but the HD7770 never appears in Device Manager, the driver is not the real problem; the hardware is probably not being detected at all [#16219673] The thread also notes that Windows 10 has no current support for the GA-H61M-S1 integrated VGA drivers, so that part is not a reliable clue by itself [#16216760][#16219428] The practical way to confirm is to try the HD7770 in another computer; if it still is not detected, the card is likely dead [#16217284][#16219673]
  • #1 16216622
    damianqo3
    Hello, I have a problem the computer does not detect the graphics card is it amd msi hd7770 ghz edition 1gb. It happened 2 months ago when I downloaded the game uplay at night then everything worked, I had the Power Off turned on for a few hours but in the morning when I got up the computer was turned on but it was black screen and nothing could be done all the same but later I put the monitor under the input from the integrated and then it turned out that the windows 10 is being updated, the computer has been working, I can normally only do everything for games, it is not suitable. I also checked if the card is in the device manager but there was only a processor and I would also like to point out that from the moment when it was bought, the integrated graphics was not detected as if it was not. Drivers were installed all the way from the manufacturer's side, but they always strangely installed once a very long time after which I had to restart the installer and re-enable, but it lasted a few minutes.
    Intel i3-3220 3.30 ghz
    Graphics card Amd msi hd 7770 ghz edition
    The Gigabyte H61M-S1 motherboard
    Ram kingston 4gb
    FSP power supply nwm which model will be needed then I will look for the box
  • #2 16216760
    kiss39
    Help: 397
    Rate: 636
    Everything is shown on the label on the power supply company and model.
    There are no drivers for WIN 10 for the GA-H61M-S1 motherboard, for the integrated VGA graphics it is under Win7
    Page to the GA-H61M-S1 Specification and downloadable drivers http://www.gigabyte.pl/products/page/mb/ga-h61m-s1rev_21/overview/
    What is rev. the GA-H61M-S1 motherboard
  • #3 16217179
    damianqo3
    rev boards are 2.1
    the power supply is a hexa series he-500 500watt
    and normally this card was working on windows 10 only most likely it broke down after the update and I can not restore it because there is no restore point
  • #4 16217284
    masterten
    Help: 268
    Rate: 284
    In 99% of cases, only one graphics card should work in a desktop at a time (ie there is always only one in the device manager).
    Which card will work by default is set in the BIOS. Most often if a PCI-E card is inserted, the integrated card is turned off, I do not know if it happened after mixing with the drivers or system updates.
    If your computer is running on an integrated card, then most likely there is a problem with its recognition (a damaged card, no PCI-E slot contacts, no 6-pin power adapter), or BIOS changes the order in which the graphics cards initialize.
    I would have checked out the hard disk / hard drives first (it does not make sense to wait for each attempt until the system starts), took out the card from the computer and put it in again. The next attempt after cleaning the card's contacts (isopropanol, or dry), the next attempt after resetting the BIOS settings, if it still does not work then you need to check the card on another computer (and another card on that computer).
  • #5 16217293
    310artur
    Help: 980
    Rate: 670
    Your graphics card died. What about this topic? Not her in the manager, she does not give a picture, the PC has switched to the integrated one.
    Where's the problem here. What is the question?
  • Both graphics outputs produce a black screen
    #6 16218815
    damianqo3
    I tried to turn on a pc without a disk and turning off the integrated in the BIOS and in the device manager the only thing happened was both black screen, and it is rather impossible that they are dirty card contacts because I cleaned them immediately after it did not work yet that the computer I had turned on for the night because I downloaded the game in the morning I got up and when I turned on the monitor it was a black screen later I switched to the integrated card and was updating windows 10 and I will add that this integrated card did not work before that.
  • Reinstall graphics drivers using integrated graphics first
    #7 16219428
    kiss39
    Help: 397
    Rate: 636
    welcome back
    Running the PC on the integrated card also have a black screen without the POST procedure of the motherboard (subtitles ...) ???
    As I wrote earlier, the Integrated Card (VGA) controllers under WIN10 have no current support or can be installed by the WIN10 system
    Try this option to run this time and start the system on the integrated card. How to run the PC and WIN10 system is to uninstall the integrated graphics card drivers and amd msi HD 7770. You can clear the residuals in the registry using the CCleaner Program (if you can handle and have had contact before). As you perform the above steps, do reset the PC (shut down the system and turn on the computer again) should automatically install the integrated graphics card. the next step will be installing the drivers for the HD 777O compatible with the system version.
    What is the version of the WIN 10 system?
  • Dedicated GPU still absent after driver cleanup
    #8 16219572
    damianqo3
    Windows 10 Home and the computer normally works on an integrated one.
    Added after 22 [minutes]:
    I did what you wrote, uninstalled the drivers, cleaned the registry with ccleaner, and so I installed the basic drivers of the integrated graphics card after a computer reset, but there is no dedicated card in the manager and in this problem, anything can happen with the card overnight as it gets I'm playing because I think it can not be burned and I'm surprised because it has not been in the device manager since then, I just did not know what happened to her
  • Graphics card likely dead; test it in another PC
    #9 16219673
    310artur
    Help: 980
    Rate: 670
    It can break down and that's what happened. How many times do you need to repeat this? The card is dead. You want to be sure to mount it in another PC.
    I do not know why these drives with drivers and what to give. The card for the computer does not exist, the drivers will not exist. There is no image from the BIOS, it is not there at all and will not be.
    In my opinion it was so - at night the card was dropped and the system got BS, after BS the computer automatically reset itself. The BIOS did not detect the card in PCI-E so it switched to the integrated one. The system got up and said that there was another card in the PC - so he started to update the helmsmen and it was windows update. The end of the fairy tale.
    After half a year, we will not recreate anything. We will not say anything.
  • #10 16221279
    damianqo3
    Ok, thanks, I will try to write something on another computer.
  • #11 16236450
    kiss39
    Help: 397
    Rate: 636
    Did you check the card on another PC?
  • #12 16345058
    damianqo3
    A good topic to close was long ago but I did not have time to write in ProLine, where I put the computer, they said that "the life of the card is over" and as if they last so many years.
  • #13 16347718
    kiss39
    Help: 397
    Rate: 636
    damianqo3 wrote:
    in ProLine where I folded the computer they said that "the life of the card is over"
    - what the lifetime of a graphics card will depend on its temperature.
    I recommend monitoring the temperature of PC components - programs.
    MSI Afterburner - MSI Afterburner, or how to enable monitoring of computer components Guide
    CPU-z
    FurMark (no more for 5-10 minutes - only checking the maximum temperature the card will reach, eg after replacing the paste or cooling)
    Core Temp
    GPU-Z
  • #14 17567330
    Ataman92
    Hello, all years. The message is mainly to Mr. Artur ... You wrote 3 x sure that the card is dead, which is total nonsense. On all forums I'm always annoyed by omniscient users ... Well, I'm sitting on the problem board H64M-S1 rev 2.1 for a few good hours the problem is that I did not solve the problem I have tested cards such as gt 710 gtx 1050 ti, radon eah 4650 radeon 7750problem such that whatever I do not do in the bios of these cards the board can not see the board working correctly on the gtx 460 gt 610 and on the above mentioned so not how you can solve this topic .. ??
  • #15 17567809
    damianqo3
    Hello everyone, I see the topic unearthed and I have already solved the problem, but I did not describe it here. Well, cold February was enough for me to put the card in the oven as shown on the videos, etc. The card "woke up" but I did not test it for a while because I bought new one and this one lies
  • #16 17568501
    Ataman92
    I understand :) but unfortunately this is not a problem with cold solder :) because the cards listed work well on other PCs. I am digging through various foreign forums and I have not found a solution like many users.
The discussion revolves around a user's issue with their computer not detecting an AMD MSI HD7770 GHz Edition 1GB graphics card. The problem began after a Windows 10 update, leading to a black screen on startup. The user confirmed that the integrated graphics were not functioning either. Various troubleshooting steps were suggested, including checking BIOS settings, reseating the graphics card, and cleaning contacts. Some participants speculated that the graphics card might be dead, while others suggested testing it in another PC. Ultimately, the user confirmed that the card was deemed non-functional by a repair service. The conversation also touched on the importance of monitoring component temperatures and potential solutions like reflowing the card in an oven, although this was not universally accepted as a valid fix.
