[Solved] MSI Afterburner - no graphics card detected
zbyszekpompa 11247 10
Why does MSI Afterburner show zero clock, voltage, and temperature readings for the Radeon graphics card in this dual-GPU laptop, and how can I make it detect the active GPU?
MSI Afterburner is likely showing zeros because the dedicated Radeon HD 8670M is dormant while the laptop is using the integrated GPU [#17132497] The Radeon HD 8650G is integrated into the processor, while the HD 8670M is the separate graphics card [#17136388] If supported, disable the integrated GPU in BIOS; otherwise set Windows and the graphics-card software to High Performance and configure GPU switching for all applications, not only full-screen ones [#17132497] Even if detection works, overclocking may provide negligible benefit and can cause thermal throttling above about 70°C or damage the laptop GPU [#17118023][#17132497]
  • #1 17116421
    zbyszekpompa
    Hello, I have a problem with MSI Afterburner. After installing the program starts up nicely but on all these clocks (MHz, mV and temperature) all these values are 0. I tried to rummage in the settings of this program but it does nothing. I count on help. :D
    I have an HP Pavilion 17-e045s laptop, win10 64 bit operating system, 8GB of RAM, AMD Radeon HD 8670M graphics card, AMD A10-5750M processor.
    • MSI Afterburner - no graphics card detected Screenshot - 20_03.png (3.53 MB) You must be logged in to download this attachment.
  • #2 17117084
    310artur
    Help: 980
    Rate: 671
    1 Drivers installed?
    2 Why do you need it on a laptop?
    spoon17
    maybe the program doesn't support your GPU.
  • #4 17117759
    zbyszekpompa
    All drivers are installed but I will try to find newer ones. I need this program to overclock the graphics card and Procek processor ?
  • #5 17118023
    Myrasz
    Help: 10
    Rate: 82
    If the program starts to work with this card at all, the effects will be negligible, but you will increase the risk of frying the GPU. You can't overclock this CPU. If this processor can be overclocked - which I doubt - the temperatures will rise and the laptop will turn off.
    Why do you want to overclock these components? I assume that for games, the only question is which ones, because you can forget about newer titles with the performance of this 2014 laptop. It can be used for games released until 2010.
  • #6 17119174
    enhanced
    Help: 964
    Rate: 885
    And these are not indications of a dormant card - after all, you have two? After all, the clocks are visible, start the game, then most should appear (but not everything). Do you have options unlocked from OC in the program options?
  • #7 17132269
    zbyszekpompa
    I checked it gives nothing :(
    GTA5 on medium settings I have 45 fps in cs go on low 115 (on a new route) This is not a huge result, but I am not asking if there is any sense in doing it on a laptop just how to do it :)
  • #8 17132497
    icosie
    Help: 298
    Rate: 239
    First question from me, what are your temperatures under stress?
    Because if more than 70, after overclocking you will have "Thermal throttling", i.e. lowering the CPU and / or GPU clock speed. It will turn out that it will be even worse as it was, because the falls will be sudden and very annoying.
    For the program to detect your card, it must be active, because what I see in the screenshot is simply a dormant card (the laptop works on the integrated).
    There are two options, either you turn off the integrated card in Bios (if it is possible), or in the settings of the card and Windows you need to set high performance everywhere and graphics card switching not only in full-screen applications.
    Some graphics cards in laptops do not have this function and the desktop then comes only with integrated.
    Regards
  • #9 17136220
    zbyszekpompa
    Spk I'll try. :)
    Added after 19 [minutes]:
    Which of these graphics cards is an integrated card and which is the normal, AMD Radeon HD 8650G or AMD Radeon HD 8670M?
    310artur
    Help: 980
    Rate: 671
    The HD 6850G is integrated in the processor
  • #11 17493537
    zbyszekpompa
    It just can't be done
The discussion revolves around a user experiencing issues with MSI Afterburner not detecting their AMD Radeon HD 8670M graphics card on an HP Pavilion 17-e045s laptop. The user reports that all clock values are displayed as zero despite having installed all drivers. Responses suggest that the program may not support the GPU, and there are concerns about the risks of overclocking on a laptop. Suggestions include checking if the integrated graphics card is active, adjusting BIOS settings, and ensuring high-performance settings are enabled in Windows. The integrated graphics card is identified as the AMD Radeon HD 8650G. The user expresses a desire to overclock for gaming purposes but is cautioned about potential thermal throttling and performance limitations.
