[Solved] Desktop PC – no monitor signal, no motherboard beep: what to check?
sithera 22818 13
Why does my desktop show "no signal detected" on the monitor and stop beeping at startup, and what should I check first?
If the integrated graphics output works with the PCI-E graphics card removed, the motherboard and CPU are probably fine and the problem is most likely the discrete graphics card or the PCI-E slot [#13301225][#13301237] Before that, reseat the RAM and try one stick at a time, because the BIOS should complain when memory is missing if the board is posting [#13298113][#13298766] Also clear CMOS with the jumper near the battery, because removing the battery alone may not fully reset the settings [#13298740] If the machine still gives no POST signals on the speaker with RAM/GPU removed, then check the processor seating and the PSU voltages [#13298113][#13298061] Since the OP later got video from the integrated graphics, the key next test is to verify the graphics card on another PC and, if possible, test another card in the same board [#13301225][#13301237]
  • #1 13297634
    sithera
    Hello, I have a problem with my desktop computer.
    Well, a bit ago the computer worked fine, no problems. The next day I try to turn it on and the message "no signal detected" appears on the monitor. I thought it might be the fault of the monitor cable, so I plugged into another monitor with a different cable, but nothing has changed. Well then another thought: a graphics card. I replaced the old graphics card but still no image on the monitor. I also noticed that before every time you turn on the computer you could hear the motherboard beep and now you can't hear it. I would like to add that when I turn on the computer, all the fans are working (those from the GPU, CPU and case). Unfortunately, I did not have another frame bone / processor / motherboard with me to check if any of these components broke. I gave it to diagnostics and found out that the motherboard is broken. It was under warranty so I sent it to Morele.net and they sent it to the manufacturer for replacement / repair. Yesterday I got an e-mail from Morele that the motherboard has already been shipped and "The form of implementation: test ok, device is working". Today I received the motherboard, connected everything correctly and still the same problem: "no signal detected". Anyone have any idea what could be wrong? I do not know if the diagnostics was bad or they checked the motherboard incorrectly on the manufacturer's website.
    Kit Specs:
    Intel Pentium G840 2.80GHz processor
    Vertex3D Radeon HD4850 1GB DDR5 graphics card
    Aerocool VP-450 power supply
    ASRock H61M-GE motherboard
    Seagate Barracuda 3.5 '' drive, 500GB
    GoodRam DDR3 4096MB PC1333 CL9
    kokapetyl
    Help: 1787
    Rate: 2101
    Remove the graphics card and frame modules, then start the computer.
    How will the album behave in this situation? (what signals from bios)
    jaras0303
    Rate: 9
    I had such a problem. Remove the battery from the motherboard and let the capacitors discharge.
    I put the tester on the pin from the power supply, which blinked until the capacitors were discharged and then left overnight
    then the motherboard settings were reset and it was going
    technikabasenowa
    Help: 138
    Rate: 445
    I to I touched the pin from the power supply with the tester that blinked until it discharged the capacitors and then left it overnight
    What was blinking there?
    As above, remove the framework, disconnect the graphics, the drives, the bios must respond (the buzzer is connected, of course), measuring the power supply voltage.
    mati211p
    HDD and data recovery specialist
    Help: 2585
    Rate: 1133
    As long as the processor and motherboard are operational, it will be like that.
    To check, as my colleagues mentioned above, without memory, graphics card, drives and disks, the behavior of the motherboard. If there are no signals from the board, check the processor, correct installation and the voltage from the power supply.
  • #6 13298149
    technikabasenowa
    Help: 138
    Rate: 445
    You're right - mental shortcut :-(
  • #7 13298622
    sithera
    Okay, yes, I found a speaker in the box, but as soon as I took it out, these 2 tips broke ... I heard 2 long beeps but it could have been more because my hand slipped. Tomorrow I will have access to a second computer and I will try to check another ram bone / power supply / processor and check these buzzer signals again. If I read these sounds correctly, there are only 2 possible interpretations of these sounds?
    sequence: 3,3,2 - wrong bios settings
    sequence: 3,3,4 - video card memory problem
    It's just that the graphics card was unplugged at that time.
    Try to remove this battery for a while? Need to do something else or just take it out, wait and put it back in?
    Another question, i.e. if the motherboard speaks, does it mean that the processor and the motherboard are working?
    djzatorze
    Help: 58
    Rate: 17
    If you hear 3 long squeaks, try removing and reinserting the RAM (preferably only one bone), or you can make sure that their contacts are clean ( source ). Removing the battery does not always reset the BIOS, sometimes it only sustains the clock. Look for the Clear_CMOS jumper near the battery and set it from 1-2 to 2-3 for a minute or two, then set it back to where it was. Then there will be a reset of the settings. And if the CPU and the motherboard are OK, the BIOS is able to perform the POST procedure and thus it will be able to communicate with the world through the loudspeaker. :)
    mati211p
    Help: 2585
    Rate: 1133
    Yes, and if it was without the components I wrote about, it indicates the lack of a graphics card and memory. How do you insert the RAM and the speaker is connected, are there any sounds then? Does the integrated graphics card work?
    swiercm
    Moderator on vacation ...
    Help: 1216
    Rate: 552
    Poorly chosen elements.
    Firstly. RAM - GoodRAMs are not so "good" - they like to play a trick - try to replace them with others.
    Secondly - Vertex3D - problematic cards - it would be worth looking for something more stable - I bet it will fail.
    Thirdly - PSU - you could put something from a slightly higher shelf (check it out)
    https://www.elektroda.pl/rtvforum/topic1199202.html
    JW After measuring the voltages on the power supply, do CLR_CMOS. Check all plugins. System speaker you have to permanently connected. You cannot miss your hand.
  • #11 13301225
    sithera
    Yesterday I took out the CMOS battery for the whole night, I also moved this jumper. In the morning I tried to fire up - nothing has changed. I took out the graphics card and plugged the monitor cable to the integrated graphics card and it works oO
    And I was sure that when I connected an old GeForce7300GT card that runs on a different computer, the problem did not disappear. It follows that the graphics card is damaged? In the near future, I will try to connect this card on another computer and see if it works there.
    It is possible that I have a broken PCI-E input on my motherboard and they have not checked it on the manufacturer's website?
    swiercm
    Help: 1216
    Rate: 552
    There is such an option.
    Until you check the cards / cards on another PC - you will not know.
  • #13 13302305
    jaras0303
    Rate: 9
    The power supply can burn your cards, I had it, with voltage fluctuations in the network he could mess up quite well. it is especially good to check it with an oscilloscope to see if it is worth anything
  • #14 13302346
    swiercm
    Help: 1216
    Rate: 552
    Right. However, these branded power supplies usually have their own protection against fluctuations in the mains voltage. This is what capacitors are mainly used for, but unfortunately they lose their properties over time.
The user reported a desktop computer issue where the monitor displayed "no signal detected" and the motherboard no longer emitted beeps during startup. After troubleshooting by replacing the monitor and graphics card, the user discovered that the integrated graphics worked, suggesting a potential failure of the dedicated graphics card or the PCI-E slot. Various responses included suggestions to remove components, reset the BIOS by removing the CMOS battery, and check the power supply voltages. The user confirmed that after removing the CMOS battery and moving the jumper, the integrated graphics functioned, indicating possible damage to the graphics card or motherboard. Further testing on another computer was recommended to confirm the status of the graphics card.
