NC Remote Control with Damaged Buttons: How to Open and Clean Contacts Safely (Model: ydhakk8n)
krzad 18228 4
  • How to open remote without breaking latches
    #1 16717110
    krzad
    Rate: 15
    Some of the buttons on the remote control do not work. I want to clear contacts, because the pilot has his years already.
    I am asking for a hint:
    How to undress the remote control so as not to break the housing latches?
    Unscrewing the only visible screw after removing the battery did not help.
    Model as per photo:
    http://tinyurl.com/ydhakk8n
    A problem similar to: https://www.elektroda.pl/rtvforum/topic2652118.html, but this does not fully solve my case.
  • #2 16717211
    andpol 33
    Help: 513
    Rate: 1146
    Gently and gently again. A small flat tool for this. It can be a screwdriver, but it must be very flat and quite wide.
  • #4 16717381
  • Opening the remote without breaking internal latches
    #5 16724299
    krzad
    Rate: 15
    mihal2002 wrote:
    It goes to APS NC + to replace faulty equipment.
    Thanks for the creative advice, although the answer is not a question.
    The advice would be OK if the pilot was under warranty and not - as in my case - he was several years old. I know I can buy a new remote. For now, I would like to try to resuscitate a copy that I used so far.
    Besides, I see that my imprecise question :-( it triggered advice that was not exactly what I wanted.
    I can not imagine opening the remote with a tool other than flat and sharp. BTW - I'm rather good at theory.
    Therefore, I will clarify the question:
    From which end / which side to begin to undermine the case of the remote control, so as not to break the internal latches?
    I would like to ask for answers from people who have practically practiced the opening of this or a similar pilot model.
