Samsung Galaxy S3: How to Fix 'com.android.system Has Stopped' Error While Closing Open Apps
naruto29 4071 10
How can I fix the "com.android.system has stopped" error on a Samsung Galaxy S3 when closing open apps without losing contacts or files?
Uninstall the Google app updates; that fixed the "com.android.system has stopped" error when opening the recent-apps screen [#16223471] If the problem returns, you can reinstall the phone’s firmware with Odin, and using the same software version should keep your data [#16218940][#16219069] Before doing any firmware upload, make a backup of contacts, messages, photos, and other files with Smart Switch or similar backup software [#16223835][#16226069]
  • #1 16218662
    naruto29
    Rate: 35
    Hello, recently there is a problem on my father's phone, while he wants to stop open applications and holds the HOME button, a message appears that com. The android system has stopped and when clicks ok the smartphone goes to the start screen.
    The smartphone can be used normally, but the message appears only when I just want to close open applications.
    I will add that the smartphone was not rooted, nothing was buried in it.
    How can I fix the problem without losing contacts, files etc?
    Do you have to worry about what it actually means?
  • #2 16218940
    gruktel
    Level 32  
    Help: 200
    Rate: 309
    Upload soft and the problem will disappear.
    GRUK Krystian Grudzień
    Chwałki 46, Sandomierz, 27-600
  • #3 16218958
    naruto29
    Rate: 35
    but uploading the software will delete the files, can it be avoided somehow and is it something serious or can you ignore it?
  • #4 16219069
    Spartan33
    Help: 41
    Rate: 97
    If you upload the same soft as you have on your phone, all the data will remain.
  • #5 16219076
    naruto29
    Rate: 35
    And how to upload it and is it as important as if I didn't do it?
  • #6 16219097
    Spartan33
    Help: 41
    Rate: 97
    Have you ever played soft by Odin?
  • #7 16219471
    naruto29
    Rate: 35
    Well, unfortunately, I don't even know where to find the original soft
    Spartan33
    Help: 41
    Rate: 97
    @ naruto29, try uninstalling the app update "google"
  • #9 16223835
    siudziu
    Help: 57
    Rate: 113
    Before you start uploading anything, make a backup of your data first, just in case you do not know how to find someone who will do it for you, you will pay a fraction of what in the case of data loss.
  • #10 16226069
    beo
    Level 37  
    Help: 298
    Rate: 238
    You can make a copy of your contacts, text messages, photos and other data using the smartswitch program - very easy to use. Should you be concerned about this? If nothing was at all messed with the phone, then something else might come up at some point.
  • #11 16235842
    naruto29
    Rate: 35
    The topic to be closed, I removed Google updates and everything returned to normal.
The discussion revolves around resolving the 'com.android.system has stopped' error on a Samsung Galaxy S3 when attempting to close open applications. Users suggest uploading the original software to fix the issue without losing data, emphasizing the importance of backing up contacts and files beforehand. One effective solution mentioned is uninstalling the Google app updates, which successfully resolved the problem for the original poster. The conversation highlights the need for caution when handling software updates and the potential for data loss if not properly managed.
