Opicum X310: Installing E144 Software on ALI3510C Processor Model - C+ Card Compatibility Issues
dj magic 4734 6
  • #1 16219193
    dj magic
    Level 19  
    Help: 9
    Rate: 31
    Good day.
    Two years ago I bought 3 Opticum HD X310 set-top boxes on the power supply. After uploading the software, everything flies without a problem. This week I bought another one - and here I have a problem. This decoder differs in that it has a built-in power supply and, most importantly, a processor. The old one is ALI3510A and here is ALI3510C. Soft as I have uploaded here is 1.09.17256. Unfortunately, he cannot see the C + card. Attempts to upload any software that I could find pops up on the E114 display. Is there any possibility or do I have someone soft for such a decoder? I see that they are selling the same model on all-route with the possibility of C + penalty
  • #3 16220924
    dj magic
    Level 19  
    Help: 9
    Rate: 31
    Well, I have this side and none is going. Is the decoder released?
    Oh, the new one with a built-in power supply is for PVR and I have HD X310 PVR in the menu in the equipment description
  • #4 16220993
    LeDy
    Help: 1990
    Rate: 2933
    See what bootloader do you have, do you have a PVR, power supply inside?
    You have it written under C +.
  • #5 16221024
    dj magic
    Level 19  
    Help: 9
    Rate: 31
    Yes it has a built-in power supply. The menu in the description has HD X310 PVR and the soft one is no PVR. ALI3510C-GS26301AA processor Ver 1.09.17256 Oct 17 2016 - like the one that is and does not let the C + card pass me
  • #7 16223546
    dj magic
    Level 19  
    Help: 9
    Rate: 31
    Good day.
    Yes, this soft is suitable. It uploaded without any problems. You can see that it was added yesterday.
    Thank you for your help :)
    I close the topic
The discussion revolves around compatibility issues faced by a user attempting to install E144 software on an Opticum X310 set-top box equipped with an ALI3510C processor. The user successfully uploaded software on older models with ALI3510A processors but encountered problems with the new unit, which does not recognize the C+ card. Various responses suggest checking the bootloader and firmware compatibility, with a helpful link provided for downloading suitable firmware. Ultimately, the user confirms that the recommended software worked without issues, resolving the compatibility problem.
