Opel Astra G 2.0 DTI 2003 - Starting Issues and Engine Shut Down After Few Seconds
Emmpo 6909 4
  • Cold-start stalling suggests fuel draining back overnight
    #1 16224389
    Emmpo
    Hello, I have a problem with starting the Opel Astra G with the 2.0 DTI 2003 engine. Namely, when it stands for a few hours, and I try to start it, it comes normally from 3/4 of a second and then it loses speed and goes out (as if the fuel was backing up) the second time I have to hold it a little to fire, not every 10 seconds. I recorded a video of what it looks like. I was at the mechanic, he said that he doesn't know what it can be, everything is fine.
    Link to the video: https://www.youtube.com/watch?v=EoE3alVbRy8
  • #2 16224863
    Bunny82
    Help: 15
    Rate: 242
    Do you have air in your fuel system when you changed the fuel filter?
  • #3 16224876
    Emmpo
    3 months ago
  • #4 16225619
    Bunny82
    Help: 15
    Rate: 242
    Replace the return hoses from the injectors and the one at the pump, if it's still bad, you need to strain your hearing and listen after turning off the hissing motor in the system connections. fuel.
  • #5 18866256
    toros80
    Hello, I have another problem in zafira 2.0 dti, after a long route, the reserve caught fire, I refueled under the cap and from that moment the problems started, the car starts for a few minutes and goes out, additionally the electric engine cooling indicator lights up when the engine is running. After stopping and reaching the engine, it fires again and goes out again. Maybe someone will suggest something or advise something?
