Intermittent Starting Issues on Opel Astra H GTC Z16XEP: Facing Errors P0201, P0202, P0203, P0204
20877 8
  • Intermittent ECU connector fault causing injector errors
    #1 16618148
  • #2 16618358
    damdam
    Help: 274
    Rate: 949
    main relay, UEC, installation?
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #3 16618386
  • #4 16618436
    sulof1601
    Help: 94
    Rate: 281
    Hello. What do you mean by the words "complete silence" lights are on but the starter is not spinning?
  • #5 16618451
  • #6 16618463
    sulof1601
    Help: 94
    Rate: 281
    Check errors in the CIM module I think there is a problem.
  • #7 16618487
  • #8 16618496
    sulof1601
    Help: 94
    Rate: 281
    The module under the steering wheel there is, among others, the immobilaizer. If you connect a good computer, it will write CIM module, you connect and you are one step ahead.
  • #9 16618515
The discussion revolves around intermittent starting issues with an Opel Astra H GTC Z16XEP, characterized by error codes P0201, P0202, P0203, and P0204. The user reports that the vehicle sometimes starts without problems but often fails to start, exhibiting complete silence when attempting to crank the engine. Initial troubleshooting included inspecting cables, cleaning the fuse box, and checking the ECU, but the problem persists. Suggestions from other users include checking the main relay and the CIM (Column Integration Module) under the steering wheel, which may be related to the immobilizer system. The user is advised to connect a diagnostic tool to further investigate the CIM module for potential failures.
