[Solved] Opel Astra G 2.0 DTI: Turbine Issues, Loss of Power, Poor Acceleration & Spinning Problem
Mvrah 6291 4
  • #1 16776648
    Mvrah
    Hello, I have a problem with my asteroid, namely it is terribly weak, as if 50 horses were lost, it does not collect at all and starts to spin poorly. I think it is related to the turbine because from time to time, after about 30 minutes of driving, you can hear otherwise the engine comes back power when I move it slightly pushes it into the seat, and the next day I barely move again etc. I don't know if the turbine turns off?
  • #2 16776692
    bubu1769
    Help: 1177
    Rate: 2374
    It would be worth removing the turbo inlet hose and seeing how it turns after firing.
  • #3 16776724
  • #4 16777074
    kmitki
    Help: 39
    Rate: 232
    Were 2.0 dci engines installed in astra g? Probably 2.0 DTI. What errors does it show? Serious diagnostics would be nice.
  • #5 16838141
    Mvrah
    The problem was solved, it was enough to replace the sensor from the turbine, the one on the left
