Procedure for Clutch Replacement in Citroen Xsara Picasso 1.6 Petrol Engine 2006
zenon11 12399 8
  • #1 16225880
    zenon11
    Help: 5
    Rate: 77
    Hello. I have a question, do you need to remove the entire sledge, to replace the clutch, or manage to move the box away? 1.6 petrol engine.
  • #3 16227163
    zenon11
    Help: 5
    Rate: 77
    Hello. I have a channel and a motor bracket too, I also have a hanger for engines my friend will tell me whether the cupid and the rest need to be taken out greetings.
  • #4 16227681
  • #5 16228918
    zenon11
    Help: 5
    Rate: 77
    Many thanks best regards.
  • #6 16244236
    zenon11
    Help: 5
    Rate: 77
    Hello. The clutch has been replaced, but after one day of driving you can not put in 3rd gear something as if blocking. The mechanism of the lines and the jack works correctly the rest of the gear ok
  • #7 16244306
  • #8 16244944
    zenon11
    Help: 5
    Rate: 77
    Rather impossible, because what can be correlated clearly even manually, after removing the connector you can not insert 3, nothing fell out, no screws left, the box was not disassembled, only the mounting on the shaft was where the speedometer cables are replaced, O-ring exchange and nothing else
  • #9 16245589
The discussion revolves around the procedure for replacing the clutch in a 2006 Citroen Xsara Picasso with a 1.6 petrol engine. The initial query inquires whether the entire sledge needs to be removed or if the gearbox can be moved aside. Responses indicate that while it is possible to remove the clutch without dropping the entire frame, using a lift and engine bracket is recommended for ease. Specific steps include unhooking lower joints, detaching stabilizer connectors, and unscrewing the steering gear from the frame. A follow-up issue arises after the clutch replacement, where the user experiences difficulty engaging third gear, leading to speculation about potential errors during the installation process.
