Oil spill on the right side of the engine 1.6 hdi 109 km 2005
arturo7731 18075 6
  • #1 16627755
    arturo7731
    Rate: 25
    Hello, all I need help: I replaced the gasket cover valve because it's liquid and now it's ok in citroen xsara picasso 1.6 hdi 109 km 2005 but I noticed that the oil leak showed up on the right turn connection I do not know what it's called to buy there even if you need two, please help me to buy the right side of the engine with the valve cover under the hose from the turbine and the air from the filter, it is screwed to the side of the engine under the hoses What is it, what to call to buy for help
  • #2 16627809
    Padrettini
    Help: 98
    Rate: 557
    arturo7731 wrote:
    on the right I do not know what it's called
    Upload some photo.
  • #3 16627835
    arturo7731
    Rate: 25
    Photo shows the place of leakage with a mockingbird on twist Oil spill on the right side of the engine 1.6 hdi 109 km 2005 Oil spill on the right side of the engine 1.6 hdi 109 km 2005
    Please, look from above, it also looks tricky at skrice, please see Oil spill on the right side of the engine 1.6 hdi 109 km 2005
  • #4 16627875
    Daro122
    Help: 165
    Rate: 751
    You have leaked from the vacuum pump when you were looking for such a gasket was not available. Unscrew the surfaces and delicately silicone with my gel. You can get gasket 459 941 between the pump and the block, but that's not the same.
  • #5 16627907
    arturo7731
    Rate: 25
    I found such a thing on the Allegro or it could be 2 seals http: // www
    Moderated By ociz:
    3.1.18. Do not send links that will cease to be active after some time. This will make the discussion lose any sense.
  • #6 16627917
    Daro122
    Help: 165
    Rate: 751
    These are seals between vacu pump and head
  • #7 16627937
    arturo7731
    Rate: 25
    So I will not do it the way you write clean oil first gasoline and later acetone because I have the same as I did with the gasket covers of the valves after the bursting I think that there will not be anything going to ruin the pump that catches me
The discussion revolves around an oil leak issue in a 2005 Citroën Xsara Picasso 1.6 HDi 109 km after replacing the valve cover gasket. The user identifies a leak near the right side of the engine, specifically around the vacuum pump area. Responses suggest that the leak may be due to a faulty gasket between the vacuum pump and the engine block. Recommendations include using silicone sealant and sourcing the correct gasket (part number 459 941) to address the issue. Users also share links to images for better understanding and troubleshooting.
