Zapchana odma Citroen Xsara Picasso 1.6 HDI 109KM 2005: Problem z zaworem, uszczelką i separatore
artur77-31 8787 3
  • #1 16720372
    artur77-31
    Hello everyone, I have a problem in the citroen xsara picasso 1.6 hdi 109 km 2005 I have been clogged with embarrassment for a long time there is this problem because I sealed the valve cover later I sealed the vacum pump because it also leaked on the gasket now the problem has returned and it is leaking again on the valve cover gasket I think that the problem is the seperator, maybe pneumothorax, is it possible to clean the washing, I do not know how and with what, I will have to unscrew the cover again, please help me if the seperator is not going to be cleaned and you will have to buy a new help valve cover?
  • #2 16720440
    E8600
    Help: 529
    Rate: 2520
    You can try to clean it before replacing it. Of course, you probably don't have an ultrasonic cleaner? Or maybe you have an orbital sander? Then you take an oblong bulb into which the valve cover will fit, pour oil on it and then mount an orbital sander to the bulb and have an ultrasonic cleaner. After such cleaning, the cover must dry.
    Such a demonstrative video.
  • #3 16720758
    artur77-31
    Maybe a good idea, but for dissolving there would be no better gasoline (95), for example, because it dissolves the oil, and this cover can not be disassembled in the middle after removal because I do not know much about it
  • #4 16734810
    artur77-31
    Hello, I unscrewed the cover for the second time I cleaned everything, it seems to me that the pneumothorax was not clogged, this time I stuck it on another silicone to a temperature of 300 degrees, it is said that it is with some glue I see it for the first time (the mechanic recommended) and we'll see what happens if I drive a little, I'll let you know later
