Best Software to Merge RAR Files: Total Commander, Split & Combine Files, File Size & Count
jaymz 9480 7
  • #1 16226981
    jaymz
    Help: 5
    Rate: 23
    What program should I use to merge two parts of rar into one file - I tried Total Commander and yes it merges two files - only the original is 3199 files and after merging 1726 - so is the Split & Combine Files program. I noticed that after merging the two files the size is correct. :shocked!:
    Best regards.
  • #3 16227141
    jaymz
    Help: 5
    Rate: 23
    OK, I have Winrar what next - no merge archives or similar options - the only option I know is to unpack all files and repack into one file again.
  • #4 16227213
    wzagra
    Help: 224
    Rate: 278
    What program to use to merge two parts of rar into one file
    - suggests that it is one archive in two files - so just unpack it. The program will connect both archives and unpack it by itself. If they are two different archives, each should be unpacked separately ...
    Unless you want to merge two separate archives into one - either "Add files to archive" or "Convert archive" or unpack both archives into a folder and pack as one again ...
    There is also 7-zip, where is the "Merge files" option.
  • #6 16278786
    jaymz
    Help: 5
    Rate: 23
    I found out that no program of this type will merge these files properly because every part has a Rar header!
  • #7 16279332
    enhanced
    Help: 963
    Rate: 883
    So open the winer.
  • #8 16583335
    jaymz
    Help: 5
    Rate: 23
    Unfortunately, I have not found the right program.
The discussion revolves around the challenges of merging RAR files, specifically when using programs like Total Commander and Split & Combine Files. Users express frustration over the inability to merge files correctly, noting discrepancies in file counts after merging. Suggestions include using WinRAR, which can unpack multi-part archives automatically if they are part of the same archive. However, if the files are separate archives, users are advised to either repack them into one file or use 7-zip, which has a "Merge files" option. A user also points out that no program can merge files properly if each part contains a RAR header, complicating the merging process.
