Combine Two A4 Pages into One PDF: Best Program & Conversion Method
Broli1988 32694 4
  • #1 7157696
    Broli1988
    I have a question, which program can convert PDF so that there are two on one page. I do not mean printing, but only converting PDF. What program and how?
  • #2 7157973
    xanio
    Help: 68
    Rate: 55
    It depends on what quality you care about.
    The greatest possibilities in this respect are provided by Adobe Acrobat Pro,
    you can also stubbornly try to import pdf files in your programs
    from OpenOffice (3.0 or later).
    There is also one more option:
    you can install a PDF printer (e.g. PDF Creator), set the print options (in Adobe Reader) so that the printout is two pages per 1 sheet and print using this virtual PDF printer.
  • #3 7158053
    Broli1988
    But I do not care about printing, only converting the pdf. I did now as you wrote and marked it to print to a file but this file is not in PDF and I want it to be.
  • #5 7160912
    Broli1988
    Well, I have this program and I do this: I turn on the .PDF document that I want to convert gives print I select the printer on cretPDF in properties I set it to do 2 pages on one sheet and then print it, enter the name of the document and it seems to process it, but it does not save it in PDF format, you can tell me where I am making a mistake or where to set something.
    Okay, I have already figured out what myk is :) thanks .
