Indesit XWDE 961480 Washing Machine: Error F05, Drain Pump Cleaned, Functional Electro Valve
Bakcyl59 6021 1
  • #1 16228886
    Bakcyl59
    Hello, we have a problem in the washing machine innex Indesit XWDE 961480 the washing machine does not finish washing. It crashes about 10 minutes before the end pops up. Problem F05 and all the diodes pass, the drain pump is cleaned, the electro valve is functional.
  • #2 16230789
    Paw_el
    Home appliances specialist
    Help: 592
    Rate: 1550
    If the pump turbine is not blocked, the washing machine drain hoses are blocking the pump motor to be replaced.
    Naprawa Pralek Automatycznych Zmywarek
    Poznańska 46, Kalisz, 62-800 | Tel.: 62 XXXXXXX (Show)
