Gorenje WX 7240 Logic - Washing machine Gorenje WX 7240 Logic does not start
sandamiano1 3675 2
  • #1 14708247
    sandamiano1
    Hello, I have a problem with the washing machine Gorenje as in the subject, namely, takes on water and how it must be released, but nothing else. The drum does not rotate, earlier I was knocked out by the plugs in the apartment or the F05 code (engine error) appears alternately. So far, reading your posts about the problems with washing machines I did the following: I checked the heater visually and it looks like it is ok at least visually. I looked at the motor cables, some not worn but also Ok. Earlier, when I turned on the washing machine (spin program) and disconnected the heater, the washing machine worked, then I connected the heater and the washing machine reacted again but about 2-3 minutes before completing the task, the plugs knocked out during the high spin speed and from now on it does nothing but picking up and releasing water. Korków no longer strikes but displays the F05 engine error. Can anyone tell me what to do? Replace the motor or throw it in the trash? Washing machine 4 years old, fear to buy new things. I will be grateful for hints.
  • #2 14709101
    peter falk
    Home appliances specialist
    Help: 1158
    Rate: 3362
    Well, check the engine, but not visually, just a meter, or there is no breakdown to the mass. Brushes in it what will happen? Ew. motor give someone a "kumatome" to check.
  • #3 14723972
    sandamiano1
    Thank you very much for valuable hints. As for the engine, I will not do it myself, because I do not know it, so far I am looking for "kumatego" what is known about it. As for the brushes I checked and they are about 19 mm. And how many should they have? It seems to me that such a length is sufficient but I can be wrong, because I saw on the Internet on videos that in a different washing machine the guest brush more or less the length of mine, he found it totally worn out and fit for exchange. So maybe I will invest in blinds in the dark, so far I started another old Bosch washing machine (WFK 281), there were evidently brushes for exchange (about 1 cm), so at least we have work in it. Unfortunately, my wife insisted on this Gorenje, so I probably will not have a peaceful sleep :) . For now, thank you for your help.
