How do I adjust the valves and injectors on a non-HPI Scania 114 from 2002?
This engine uses Scania PDE unit injectors, not HPI, and for a 400 hp unit the valve clearances are 0.45 mm on the intake side and 0.8 mm on the exhaust side [#16233971][#16231004][#16232220] Turn the engine to the right when viewed from the fan side before adjusting [#16240069] Measure carefully and recheck several times, because over-tightening the pump injectors can damage them [#16242433]
It would be best if you saw the regulation in practice with your own eyes, it would certainly be easier. Measure carefully and check even a few times just to be sure, if you over-tighten (adjust) the pompo injections you can damage them. Congratulate courage and good luck!
The discussion revolves around a request for a schematic diagram of the valve configuration for a Scania 114 (2002) model that does not utilize HPI (High Pressure Injection) technology. Participants provide insights on valve adjustments, including specific measurements for suction and exhaust clearances, and emphasize the importance of careful measurement to avoid damaging the pump injectors. The author expresses a desire for guidance as this is their first attempt at valve adjustment, seeking additional tips and practical advice from the community. AI summary based on the discussion. May contain errors.
