Huawei E5573s - 320 with PLAY - how to increase its range at home
wawior 5847 5
  • Wi-Fi extender compatibility without WPS button
    #1 16238667
    wawior
    I looked through a lot of topics, but nowhere did I find a clear answer on how to increase the WIFI signal range with my so-called Huawei E5573s - 320 ?? I know the wrong option I chose with this equipment but I will not undo it, so please help.
    Will I increase the range using, e.g. WIFI signal amplifiers e.g.
    tp-link tl-wa850re-amp-signal-wifi-300mb-
    or
    8level-WRP-300-amp-signal-wi-fi-
    Please reply whether it will work if I don't have the WPS button on my Huawei device ?????
    Thank you for your help
    Connect E5573s to Gargoyle router via USB
    #2 16238710
    bogiebog
    Help: 2569
    Rate: 1530
    Try these amplifiers, WIFI in the building is a lottery, nobody will predict how it will work for you.
    Added after 6 [minutes]:
    Is the E5573s a hilink router?
    ie can you connect it to your computer with a usb cable and you have a net after a usb cable?
    Yes ? you can connect it to a WIFI router with preloaded gargoyle, e.g. WR1043v3, there should be better wifi, but as soon as practice shows.
    Replacing the repeater with Gargoyle routers and wired APs
    #3 16238748
    matek451
    Help: 4352
    Rate: 5808
    You have two solutions, the first is to use the WiFi repeater function, e.g. this WA-850. The repeater mode requires an appropriate signal from E5573, it must be in such a place that the signal strength from MiFi is minimum -70dBm. Interference-sensitive mode, not very stable and because the WA-850 has one radio for receiving a WiFi signal and further broadcasting, the speed is assumed to be half the speed. Somehow it works but d .. does not break, personally I do not recommend. The second solution is, as a colleague writes, purchase WR-1043 v2 / v3 change FW on it to Gargoyle 1.6 or 1.9 and appropriate configuration of the WAN port under E5573. If the range of the WR-1043 is not enough, you will connect an additional AP cable at the bottom after the LAN. Instead of WR-1043, you can search for support E5573 http://allegro.pl/router-openwrt-3g-lte-nexx-wt3020f-nowy-przenosny-i6694600673.html /, on it change OFW to http: //dl.eko .one.pl / gargoyle-pl / chaos_calmer / ramips / gargoyle-1.9.1.2-ramips-wt3020-8M-squashfs-factory.bin and WAN port configuration for E5573. For this as an AP over a LAN cable WR-841 configured as an AP http://tplink-forum.pl/index.php?/topic/668-router-bezondowy-jako-ap-punkt-dost%C4%99powy/ Nexx not has problems with powering modems / MiFi via USB. As a power supply for it, you can use a USB 2A phone charger. You must also remember that on E5573 you will not turn off the WiFi network and you will have two. One with E5573, the other with WT3020 at the top and in it an additional AP at the bottom with WR-841. You can then set the 5GHz band on E5573.
  • #4 16238863
    wawior
    Thanks for the help,
    Yes, my router is a hilink and I use it primarily on a desktop computer, but the WIFI network, which it creates above all, is weak and additional, if I turn off the computer, after some time Huawei E5573 turns off ..
    I will use this Nexx, because I have a place with a LAN cable in the attic (where I don't have WIFI now) there will be one access point with this device (I will switch my E5573 to 5GHz band)
    floor below with the cable I will connect proposed WR-841 configured as AP, to it a desktop computer plus there will be a WIFI network on the next floor, I will have one floor below and there I will eventually connect tp-link-tl-wa850re and try to connect with WR-841 through pressing WPS.
    Yes, one question in the inheritance on the Neostrada, I have a working and not old sagemcom fast 2704, I wonder if it could be done to walk like WR-841? with these configurations I can't handle it myself, with the tplink configuration link that bogiebog you pasted I can handle, but my sagemcom would probably be a problem to configure ???
    Adam
    matek451
    Help: 4352
    Rate: 5808
    Yes, you can use Fast as an AP, it has LAN ports and the configuration is similar to WR-841 as an AP. Generally, it will change the LAN address on it. If Nexx will have 192.168.1.1 (this is the default address on Gargoyle) then you will give it 192.168.1.1, turn off the DHCP server on it, and then set up the WiFi network. i.e. the same name as on Nexx or another, security and password are the same and the WiFi channel is different than on Nexx. in case of problems ask. If you want to buy from this auction, which I have linked, the seller can change OFW to Gargoyle 1.9 and configure it under E5573.
  • #6 16238922
    wawior
    Thank you very much!!
    I'm buying NEXXA and trying to configure my Sagema
    I will write on a regular basis
