[Solved] Connecting Huawei E5573 Mobile Modem to Stationary Router: Compatibility and Signal Issues
Darki333 9045 15
How can I connect a Huawei E5573 mobile modem/router to a stationary router, and which of the listed routers will work reliably?
It is usually not worth trying to pair the Huawei E5573 with one of those routers; the more reliable fix is to buy a proper stationary LTE router and, if needed, add a separate access point for Wi‑Fi coverage [#17290994] If you still want to use the E5573, the TP-Link TL-MR3420 v2 works with it on official firmware, but it is considered a poor choice for LTE modem support because of USB power and modem reset problems [#17290994] The D-Link DWR-118 does not work with the E5573 on stock firmware, but the A2 version can be configured with alternative firmware such as LEDE/OpenWRT [#17290994][#17324349] Asus compatibility with HiLink/MiFi devices was described as uncertain, so it was not a recommended option [#17290994] For your budget, forum members recommended moving to a Huawei B525 or, cheaper, a B315/E5180; the B525 was specifically recommended as the better choice and some posts noted Play units to avoid IMEI-lock issues [#17291668][#17294374][#17291587]
  • Need a compatible router to stabilize E5573 Wi‑Fi
    #1 17290895
    Darki333
    I would like to ask for advice. I have a Huawei E5573 mobile modem / router. The device performs quite well in general, but when connected, wifi often breaks the signal for several seconds (the further away from the router, the more often). What's more, a reinforced load-bearing wall runs through the middle of my apartment, so the signal strength from this toddler is barely breaking through it.
    However, I did not notice the disconnection when I had the E5573 plugged directly into the computer via USB.
    Therefore, in order to strengthen the wifi signal and stabilize the connection, I decided to buy a stationary router for the E5573. However, this is not a typical connection and from what I read, not all routers support the E5573.
    I thought about one of the following (due to the relatively low cost and good user ratings), although I would like to ask you for your opinion which would be the best in my situation and whether any of them can be reasonably combined with the E5573 to get the intended effect.
    -Asus rt-n18u
    -Asus rt-ac1200g +
    -D-Link DWR-118 (or 116)
    -TP-link tl-mr3420 (v1 or v2)
    Thanks in advance for all the advice and help!
    Alternative firmware and LTE router recommended
    #2 17290994
    matek451
    Help: 4352
    Rate: 5808
    MR-3420v2 works with the official FW with E5573, but this router is practically not suitable for LTE modem support (USB power supply problems, modem reset), especially on the official FW, they work better on an alternative one. Asus and modems / MiFi is a mystery, it is possible that they will work on an alternative FW but with HiLinks they worked poorly. DWR-118 on the official FW does not work with the E5573, but on it there is an alternative soft from Cezary, i.e. LEDE from LUCI working on the DWR-118A2. In this software you can configure the router to work with the E5573. In general, the idea itself is rather bad at a time when a stationary router with LTE can be bought for PLN 150 and those with LTE-A and LTE band aggregation for PLN 250-300. In case of problems with WiFi coverage in the apartment, it is best to use an additional AP, connected to the LTE router via LAN cable or PLC transmitters via the electricity network.
  • #3 17291096
    makosuu
    Help: 369
    Rate: 370
    If a mobile router for stationary applications is enough for you, buy the E5180 or B315. They will fulfill their task perfectly.
  • Request for a proven LTE router with external antenna support
    #4 17291333
    Darki333
    The thing is, it's not enough. If it were enough, I would not look for a suitable router. I wanted to solve it this way because sometimes I have to take the E5573 with me when I go to the countryside. Then I could unplug it and take it with me, but if the LTE stationary router that you propose really significantly improves the comfort of use (first of all, stability and range, because the speed has daily fluctuations of about 30 Mbit / s and it will probably not help) I could also drive a stationary one, because I do not use the Internet while running - only on the spot.
    So thank you for the advice and I think I will actually give up trying to connect the E5573 with anything, because the manufacturer clearly did not want to, and why dig with the horse.
    For this, I would like to ask you to propose a good, proven LTE stationary router with a built-in model for PLN 250-300, so that it will already be a solid device, with which I will not have to worry about it. It would be good if such a router could connect an external antenna, because its use allows me to improve the link speed by about 1500% in the countryside :)
  • #5 17291396
    makosuu
    Help: 369
    Rate: 370
    Huawei B525. Supports band aggregation, connect external antennas.
  • #6 17291502
    Darki333
    It is indeed a very nice router, except that it is almost double my budget. And something good within PLN 300? It may and may not be without this external antenna if it makes a difference in price.
    makosuu
    Help: 369
    Rate: 370
    You can buy Huawei B525 for PLN 300, even the better one from Play or Plus. Those from T-Mobile are cheaper because they have cut soft and blind connectors (which can be repaired), but it is not profitable to take them because with Play more expensive PLN 30-50 and there is no limited software, as well as the risk of IMEI lock.
  • #9 17294366
    Darki333
    Thanks for the tips. Is there a possible cheaper alternative for me to buy something with a guarantee for PLN 300?
    What is the difference between, for example, B525, E5180 or E5186?
    makosuu
    Help: 369
    Rate: 370
    From B315, E5180 eg WiFi AC, band aggregation. Design mainly from the E5186. And you have a new B525 with a guarantee for just over PLN 300.
  • #11 17294604
    Darki333
    Ok. Thank you very much for help :)
    Can I ask for a link to the offer you are writing about?
    makosuu
    Help: 369
    Rate: 370
    I meant the offer from @ matek451, but there is no guarantee at all, contrary to what he wrote :) With a guarantee I found https://allegro.pl/router-huawei-b525-komplet-gwarancja-i7415705920.html
    If you want to be 100% new, it is not difficult to find a new B315 at this price
    https://allegro.pl/router-wifi-4g-huawei-b315-lte-nowy-gw-24msc-i7419073094.html#thumb/1
    matek451
    Help: 4352
    Rate: 5808
    As there is a receipt from Play, B525 bought at a pawnshop has a manufacturer's warranty. Those from Play are safe because they are bought immediately and the fee is included in the subscription. Those from T-Mobile and Plus are in installments and remain the property of the operator until their repayment, i.e. two years. If someone stops paying for the contract, T-Mobile, Plus block the equipment by IMEI and we have a block.
    jarek7714
    Help: 85
    Rate: 119
    Therefore, in the case of such a purchase, it is better to prepare for the change to modded soft at the start.
  • #16 17728433
    Darki333
    Ultimately, I bought a Huawei B715. I recommend. Internet more than 2 times faster in the same place and even more importantly - extremely stable. It used to be disconnected at least twice a day, now it doesn't happen at all.
The discussion revolves around the compatibility and signal issues of the Huawei E5573 mobile modem when connected to a stationary router. Users report frequent Wi-Fi signal drops, particularly through obstacles like load-bearing walls. Suggestions include using alternative firmware for routers like the DWR-118 to support the E5573, but many recommend purchasing a dedicated LTE router instead. The Huawei B525 is highlighted as a strong option due to its support for band aggregation and external antennas, although it may exceed the user's budget. Other models mentioned include the E5180, B315, and B715, with users noting significant improvements in speed and stability with the latter. The conversation emphasizes the importance of selecting a router that ensures reliable connectivity and performance.
TL;DR: Trying to pair a Huawei E5573 with a home router is fragile; experts suggest buying a stationary LTE router instead. "The idea itself is rather bad." Budget LTE‑A routers cost PLN 250–300. [Elektroda, matek451, post #17290994]
Why it matters: E5573 and USB‑modem owners can stop dropouts, extend coverage, and choose proven LTE routers.
How do I fix Wi‑Fi dropouts with a Huawei E5573 behind a reinforced wall?
Use an additional access point connected by Ethernet or PLC powerline adapters. Let the E5573 feed Internet and keep Wi‑Fi duties to the AP. This approach stabilizes coverage and reduces short dropouts. It’s the recommended topology for tough in‑home Wi‑Fi scenarios. [Elektroda, matek451, post #17290994]
Can I pair the E5573 with a TP‑Link MR‑3420 to extend Wi‑Fi?
TP‑Link MR‑3420 v2 can detect the E5573 on official firmware. However, it is not suitable for LTE modems due to USB power and reset issues. Stability improves with alternative firmware, but results remain inconsistent. Consider this only as a stopgap. [Elektroda, matek451, post #17290994]
Will Asus RT‑N18U or RT‑AC1200G+ work with E5573 HiLink?
Asus support for MiFi and USB modems is inconsistent. "Asus and modems/MiFi is a mystery." Some units work with alternative firmware, but HiLink devices performed poorly. Avoid relying on Asus for E5573 compatibility. [Elektroda, matek451, post #17290994]
Does the D‑Link DWR‑118 A2 work with E5573, and how?
On stock firmware, the DWR‑118 does not work with the E5573. Install LEDE/OpenWrt by Cezary on the A2 hardware revision. Then you can configure the router to operate with the E5573. "Does not work on the official FW" summarizes the stock limitation. [Elektroda, matek451, post #17290994]
What’s the best budget upgrade path—stick with MiFi or buy a stationary LTE router?
Choose a stationary LTE router instead of chaining a MiFi to a router. Entry LTE models start near PLN 150. LTE‑Advanced routers with carrier aggregation cost about PLN 250–300. For range issues, add a LAN‑backed AP or PLC link. [Elektroda, matek451, post #17290994]
If I only need basic LTE at home, which simple router works?
If basic stationary use is enough, pick Huawei E5180 or B315. They handle everyday home LTE tasks well. This keeps things simple without juggling a MiFi bridge. Both models are known to "fulfill their task perfectly." [Elektroda, makosuu, post #17291096]
Which stationary LTE router around PLN 300 is recommended?
Huawei B525 is the standout around PLN 300. Prefer units from Play; T‑Mobile variants are cheaper but limited. Those often have restricted software and blind antenna connectors. Spend slightly more for an unrestricted Play unit. [Elektroda, makosuu, post #17291668]
What are the differences between Huawei B525, E5180, E5186, and B315?
B525 adds Wi‑Fi AC and LTE band aggregation compared with B315 or E5180. Its hardware lineage aligns mostly with the E5186 design. That makes it a stronger platform for modern LTE networks. It is the more future‑proof choice. [Elektroda, makosuu, post #17294374]
Can the B525 use external antennas and aggregate bands?
Yes. B525 supports external antennas and band aggregation. That combination helps boost signal and throughput when conditions permit. For rural use, external antennas can significantly improve links. Pick the B525 specifically for these features. [Elektroda, makosuu, post #17291396]
How do I safely buy a used B525 without IMEI risks?
Request proof of purchase from Play to keep the manufacturer’s warranty. Play‑sourced B525 units are safer. T‑Mobile and Plus sell hardware on installments and retain ownership until repayment. Unpaid accounts can trigger IMEI blocks on those devices. [Elektroda, matek451, post #17294733]
Is there a cheaper alternative with OpenWrt and a USB modem?
A cost‑effective alternative is DWR‑118 A2 with a Huawei E3372h USB modem. With OpenWrt 18.06, this combo "works great." It provides 2.4/5 GHz Wi‑Fi and mixed Gigabit/Fast Ethernet ports. Expect typical used pricing around PLN 60–90. [Elektroda, Anonymous, post #17324349]
How do I set up a second access point to improve coverage?
  1. Run an Ethernet cable or plug a PLC powerline pair between rooms.
  2. Connect an access point to the remote end and power it on.
  3. Configure the AP to bridge LAN and join clients, then test coverage. [Elektroda, matek451, post #17290994]
What did the OP ultimately choose, and what performance did they get?
The OP switched to Huawei B715. They saw "more than 2 times faster" speed in the same place. Stability improved drastically, eliminating daily disconnects. That upgrade solved both performance and reliability. [Elektroda, Darki333, post #17728433]
Can I stabilize E5573 connections without buying new hardware?
USB tethering from the E5573 to a computer proved stable. Wireless dropouts appeared mainly over Wi‑Fi and distance. For a quick fix, use USB when possible. If wireless is needed, plan for an AP or PLC backhaul. [Elektroda, Darki333, post #17290895]
Are band aggregation tweaks possible with USB modems on DWR‑118?
Yes. On DWR‑118 A2 with OpenWrt 18.06, use Huawei Manager to select bands. This enables aggregation on compatible modems like the E3372h. The author reports reaching "maximum transfers allowed by my modem." Expect performance up to the modem’s limits. [Elektroda, Anonymous, post #17324349]
I need a guaranteed‑new router around PLN 300—what model fits?
If you need guaranteed‑new hardware around PLN 300, look at Huawei B315. New units at that price are easy to find. It is a solid, simple LTE router for home use. You can upgrade later if you need carrier aggregation. [Elektroda, makosuu, post #17294705]
