Huawei e5573 and PLUS internet, device change and network construction
Dabog 6408 5
  • Wi-Fi access restriction suggests router overload
    #1 16488493
    Dabog
    I warmly welcome.
    I have internet from PLUS and the Huawai e5573 device, which has so far worked well. It was intended for a small office with two computers and stable, stable network access. The choice fell on such a solution due to mobility (a good chance of changing the location) and an offer quite favorable at that time (in combination with several mobile subscriptions).
    The router was connected to one of the computers, and the other received a WIFI signal (in addition, the printer worked in the network). Sometimes a yellow exclamation mark and "access restriction" appeared on a computer with WIFI access. However, the problem did not occur often, so it was not troublesome.
    Currently, however, when connecting an additional 1 or 2 computers, "access restriction" appears much more often (sometimes even several times an hour) and seriously hinders work. My guess is that the device is not designed to work with so many computers, hence the problem.
    I tried to make changes to the router settings, but it did not bring the expected results. Sometimes the "access restriction" appears really often, but there are times when computers don't experience it for several hours. On a computer connected by cable, everything works correctly, but devices working after wifi require a restart of the network to return to live.
    You probably need a new router that works with LTE and here I could use some help.
    The contract is also ending, so I can choose something from PLUS, but probably a better solution would be to buy a router on the market. I want stable network access for 3-5 computers + a printer, in a small space (2-3 office rooms). The network needed for office work, so emails, chat, web service etc. - no games or large files that need to be downloaded.
    The current location is Krakow (30-868) - because it can also have some significance (although the problem with "limiting access" also occurred in other locations).
    Thank you in advance for your help and interest in the topic.
    Test LTE1800 and LTE800 signal parameters on E5573
    #2 16488539
    matek451
    Help: 4352
    Rate: 5808
    This is not a router but a mobile toy, The idea of taking it from Plus for such applications looks like a bad joke. ' Thank "business advisor of the worst mobile operator. With this extension of the contract in Plus is another joke, without any equipment? What are you now DL / UL on this toy? What signal parameters are you connecting with LTE1800Aero2 or LTE800sferii. Test both bands on E5573 using http://www.lte-anbieter.info/ltewatch/count_huawei.php?Datei=ltewatch_h or https://www.dropbox.com/s/x3f5jxw89rjk0i9/E5186%20Toolbox_latest.zip?dl=0 After logging in in them on e5573 shows BTS data and signal parameters. You can force LTE1800 and then LTE800 in them. Also do speedtests on each, show screenshots from programs and speedtest. The nearest BTSs LTE1800aero2 are Ściegiennego 93 and Medyczna 9. On the first also LTE800sferii and probably LTE-A from these two bands.
  • Need to test LTE1800 and carrier options
    #3 16488568
    Dabog
    For nearly a year, the device and Internet access using this toy worked quite well and was sufficient for our needs. Now, however, the device no longer fulfills its task and I need to select / change something. The speeds I had were DL 8-4 mega, and UL about 2-3. (it's enough for the office's needs)
    As for the worst network ... I've heard similar reviews about T-Mobile and Orange, but I'm open to suggestions. I also have internet with 3 mobile subscriptions plus one mobile landline number and it costs me a penny.
    However, I am not attached and I can try a different solution - although some monthly renewal or combining is out of the question. You can suggest a different network (I read about your suggestions from play, but I would prefer something ... simpler :) - besides, I have to take on the company.
    Tomorrow I will test and try to delve into the subject (LTE1800Aero2 and sferii, because it says nothing to me :) ).
    Recommend LTE-A routers instead of Plus toy devices
    #4 16488616
    matek451
    Help: 4352
    Rate: 5808
    I didn't ask about how the toy worked because I know it perfectly and for me using it for such a purpose is a mistake from the beginning. No advisor who respects a business client should offer him, two years ago Plus had a LTE router or B315 on offer and one had to take it. Speeds on LTE? If so is the misery but also the norm in Plus for Krakow, show speed tests and do recommended tests with these programs. The opinions about Orange or T-mobile on the part of people without the concept of mobile internet do not matter. These operators have overtaken Plus by several lengths and their business offers and not only beat him on his head. Play has at Kurczaba 5 BTS with a set of LTE licenses and band aggregation. But if Plus suits you, then extend the contract after testing but with the equipment. Currently on offer is a router with LTE-A or DWR-960 for 25.50 months. But I don't recommend it. In the absence of others from LTE-a you can buy yourself B525 (those from T-Mobile for about PLN 400 from Play for PLN 500), E5186 or B618. They support LTE1800 + 800.
  • LTE speed tests show 7–10 Mbps on Plus
    #5 16488741
    Dabog
    I will do the tests and come back with the results.
    In general, the Internet is to operate not only in this location (but mainly in this). I understand that it would be much more prudent to be interested in PLAY or Orange?
    Any specific tariffs, devices in their offer?
    I am not entirely satisfied with PLUS (cellular range). Where ORANGE works PLUS has a black hole. I also care about the landline number (this option was probably available on PLAY)
    EDIT: I'm satisfied because I didn't have requirements for the office. At home, I would probably throw the device and the whole PLUS out the window :) . Especially since I have 120 mega on a permanent connection.
    The advantage of LTE and mobile Internet is that it is ... mobile
    Added after 12 [hours] 54 [minutes]:
    matek451 wrote:
    ... show speed tests and take recommended tests with these programs.
    LTEWatchH - does not show any results.
    Second program:
    When it comes to speedtest:
    Unfortunately, I can't find anywhere where (and if) I can change to LTE1800Aero2 or LTE800sferii.
    Of course, I did several tests and the results were similar: between 7-10 mega DL. These results seem fully satisfactory for the needs of the office.
    I know that Fiat Seicento is not the top of the automotive industry, but if you do 500 km a month it is enough :) (if you understand the hints).
    More important is the distribution of this signal and the creation of a WIFI network. Maybe I will actually consider the offer from PLAY together with Huawei B525 (I saw an interesting combined offer) - but I will have to spend myself to the end of the contract with PLUS.
  • #6 16496971
    matek451
    Help: 4352
    Rate: 5808
    Connection with BTS Plus at Ściegiennego 93, most likely with LTE1800Aero2. poor signal parameters and SINR /. You need to check the operation of this band under BTS. Dual LTE1800MHz antenna needed.
