Audi A4 B6: Driver & Passenger Window Mechanism Replacement - Windows Not Lowering/Lifting
ewenement22 7464 8
  • #1 16240334
    ewenement22
    Rate: 93
    The line frayed and got caught in the driver's window lifting mechanism.
    I disassembled the windows, I replaced the whole mechanism and unfortunately now neither the driver nor the passenger lower the window. What is going on? Why could this happen? Can connecting VAG help? I am asking for urgent help because it is cold outside and I have the passenger window down and I cannot lift it. What could happen? And how do you try to fix it?
  • #2 16240380
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    ewenement22 wrote:
    What could happen?
    E.g. the fuse has blown or there is no communication with the door module or no power due to the door grommet.
  • #3 16240391
    ewenement22
    Rate: 93
    Door guides? what's going on;> ??
    Where is the module located?
    The fuse will soon try to diagnose which one
    Added after 1 [hours] 56 [minutes]:
    VAG showed such things
    https://wklej.to/JpWna
    The driver window switch is not lit. The passenger light is on ...
    Added 50 [minutes]:
    What could have happened, what could I have done when dismantling the door, that such errors had popped out and the opening / closing of the passenger window also didn't work ... I didn't touch anything there.
    Added after 23 [minutes]:
    I upload logs translated by http://vwonline.pl/
    https://wklej.to/3Hj9B
  • #4 16241781
    ewenement22
    Rate: 93
    What to do please tell me. Maybe I can solve this problem myself.
  • #5 16241786
    andrzej20001
    Help: 1578
    Rate: 6669
    Yeah, if the vag doesn't show you which fuse and cable, then the reason is over .... to the car workshop, rather go.
  • #6 16241805
  • #7 16242038
    Help: 1405
    Rate: 6430
    ewenement22 wrote:
    I dismantled the windows, replaced the whole mechanism
    I will tell you that you are cool, I am taking a dentist syndrome when I have to replace the lift in A4 B6.
    I'd like to burn a car.
  • Checking door module power and separate window fuses
    #8 16242921
    ewenement22
    Rate: 93
    I say this with the left rear door has long been a problem that despite the fact that I opened it, the computer did not see it and, for example, after a while closed the car itself. Because he thought that after opening the central door was not opened. This also sometimes happens with the tailgate.
    All these fuses
    I checked and they are all ok. Unless there are others somewhere else that I need to check? I have heard from one mechanic that there is a separate fuse from the panes. But I think that if he was released, the right door would not get power and they will get ...
    In the cube, how can I check the power supply? On which pins?
    Oddly enough, before checking the fuses, the central worked on all doors and now does not work on the driver's door.
    Some fuses or smaller ones had to be removed to check and maybe that's why?
  • #9 16845610
    ewenement22
    Rate: 93
    I don't know if it is possible and how it happened, but the electronics said that the comfort module has fallen. Supposedly he repaired it. He fixed the glass and took PLN 250 :)
The discussion revolves around issues with the window mechanisms of an Audi A4 B6, specifically after a frayed line caused problems with the driver's window. The user replaced the entire mechanism but now both the driver and passenger windows fail to operate. Possible causes suggested include blown fuses, lack of communication with the door module, or power issues due to the door grommet. The user is seeking urgent assistance as the passenger window is stuck down in cold weather. Follow-up messages indicate attempts to diagnose the problem using VAG diagnostics, with mentions of potential issues with the comfort module and the need to check fuses. The user expresses frustration and seeks advice on troubleshooting steps.
