[Audi A4 B5 FL] - Interior lighting flashes when the passenger door is opened
Andrzejkryk 8661 12
Why does the interior light flash when a passenger door is opened on an Audi A4 B5 FL, and where should I look for the fault?
Check the instrument cluster wiring/connectors first: one case was caused by a bent pin in the clocks, and correcting it stopped the flashing interior lighting [#20270306] The door-open signals also pass through the cluster, so a bad ground or a fault in the cluster path can make the relay chatter; one reply specifically pointed to poor earth and suggested eliminating the clocks from the circuit as a test [#16451986] Another explanation was that the door lock has two microswitches and both must work correctly; if one signal is weak or missing, the lighting relay can go crazy and the lamps start pulsing [#20270639]
  • Relay 382 links flashing to central-locking actuator noise
    #1 16449383
    Andrzejkryk
    Hello, I saw that there is a similar topic but it was closed, hence I write a new one.
    The patient is A4 B5 FL 2001
    The problem is the flashing interior lighting when any passenger door is open and the ignition position, although sometimes without ignition it can flash rhythmically. By opening the driver's door, the lighting stops flashing and is lit normally.
    Checked and cleaned contactors in the door of the driver and passengers, plugs cleaned at the left and right pillars.
    The problem disappears after removing the 382 relay, but then there is no lighting of the legs and door lamps.
    I will add that when the relay blinks and ticks, from the trunk lid, the servomotor from the central seems to buzz to the rhythm of the blinking, disconnecting the mass at the post, the servomotor in the flap begins to buzz very much, something like a welder.
    Does anyone know where to look for the problem here? I will replace the central pump, but I can't find exactly the right one, they have older models everywhere.
  • #2 16449861
    decybel91
    Help: 1024
    Rate: 4236
    b5 fl no longer has a central pump, only everything electric. If so, you have water in the comfort module.
  • #3 16450659
    Andrzejkryk
    The central pump is in FL, the electric is in VW, there is no water anywhere, I also looked at the plate if there are no cold solders but you can not see anything.
    I just don't know why the module feeds the mass to the relay as if pulsating, once it is and it disappears all the time, which causes the light to pulsate.
  • #4 16451176
    UCY 7400
    Help: 37
    Rate: 75
    Haven't you put in a counter with audi A6?
  • #5 16451298
    Andrzejkryk
    Not everything is original, nothing has been changed or bred, except that I am only able to re-iron or replace the central pump.
  • #6 16451417
    UCY 7400
    Help: 37
    Rate: 75
    And fis displays each of the doors? If you have a full fis, disconnect the gray cube from the meter and see if it is still blinking.
  • #7 16451687
    Andrzejkryk
    Hey, yes FIS normally displays each door separately, all the microswitch in the door are functional, everything works and indicates as it should except that the lighting is flashing. Thanks, tomorrow I'll try to disconnect the cube and see what it changes. And why do you suspect a meter?
  • #8 16451986
    UCY 7400
    Help: 37
    Rate: 75
    Somewhere you have poor weight, sure.
    The signals also go through the meter, if you checked all the rest then it would be useful to eliminate the clocks. I suspect that if you change the pump, it won't change anything.
    We have processed so much with a friend that he had an accurate fis and rectifier diodes had to be given to the counter signals from the door.
  • #9 20237912
    renegat207
    Rate: 11
    Gentlemen, has someone solved this problem? Because I have been struggling with it for a few days and the only thing left for me is to replace the pump / central module. The illumination only flashes when the right front passenger door is opened with the ignition key turned off.
  • Ground fault likely beyond the passenger door switch
    #11 20237946
    renegat207
    Rate: 11
    Ok thanks but I’ve already read this topic. For me, the problem is evidently low weight, but not at the end of the right front passenger door, but somewhere further in the installation. I tried with rectifying diodes, I gave the mass directly to the gray cube meter pin and the info about the open door shows on the FIS, so it’s not the meter fault. I cleaned all the cubes from the switchboard, and also those on the back of the pump. I have not checked yet if there is a mass on pin 1 of the green cube after opening the door. Interestingly, when I gave the additional weight through the diode on the meter pin, the backlight stopped flashing, but after closing the door, the lamp under the legs went out and the one on the headliner did not.
  • Bent clock pin caused interior light flashing
    #12 20270306
    Andrzejkryk12345
    Hello, I will describe what was with me, although the car was sold a long time ago, namely, after removing the clocks, it turned out that one pin in the clocks was bent, someone had to disassemble the clocks and bent the pin when plugging in the plug. Correcting the pin solved the problem of blinking lighting.
    The car was freshly bought and the dealer was probably rummaging around there, maybe something with the mileage, but after that the problem resolved.
  • Weak microswitch signal caused interior light flashing
    #13 20270639
    renegat207
    Rate: 11
    [Audi A4 B5 FL] - Interior lighting flashes when the passenger door is opened I've figured out more or less what's going on. There are 2 microswitches in the lock's end, but why 2? I played with them and it turns out that 1 is from the signal for lighting the legs and 2 is for the inf. about opening the door for the interior lamp. These signals (mass input) must coincide with each other, otherwise the relay goes crazy with the interior lighting. As if the first 1 micro gives a signal to open the door directly to the relay, and 2 goes through the central controller, i.e. a pump. So, to sum up, 2 microswitches must be operational. Moreover, the meter goes to 5 different signals, PP, LP, LT, PT door opening, boot lid opening and 6 bridged signal to open all doors. The 7th signal is the bonnet flap opening, but it is only needed to clear the message about the low oil level in the engine. Translating into simple language, the lighting lamps do not care which specific door we will open, it is important that the lamp comes on after opening the door, the signal goes from the central pump to the relay and the meter, while the signals about opening the secondary doors go to the meter separately and also through the lighting relay with the distinction between the leg illumination lamps. For me, not 1 of the microswitches was leading, but too "weak", hence the 0 1 signal was not always correct.
The discussion revolves around a flashing interior lighting issue in a 2001 Audi A4 B5 FL when any passenger door is opened. The problem persists even with the ignition off, and the lighting stabilizes when the driver's door is opened. The user has already cleaned the door contactors and checked the wiring but suspects a fault in the central pump or comfort module. Responses suggest that the issue may stem from poor grounding or faulty microswitches in the door locks, which are responsible for signaling the interior lighting. One user resolved a similar issue by correcting a bent pin in the instrument cluster. The importance of ensuring all microswitches are operational and checking the connections to the central module is emphasized.
