Switching of 230V appliances - on one phase the washing machine and the boiler overload the phase
zinhosky 1851 1
  • Automatic boiler cutoff when the washing machine runs
    #1 16244070
    zinhosky
    There's a washing machine and a boiler on one phase in the townhouse (old, with old plumbing), when both appliances are running there's an overload and jams pop up, for now I'm doing it so that when I turn on the washing machine I take the boiler out of the socket.... you know, if the water doesn't reheat for an hour/half and a half, nothing happens - the problem is that you have to remember to turn the boiler back on after you've finished washing - the question is whether it wouldn't be possible to make some kind of "automatic"
    is there any solution where switching on the washing machine would automatically cut off the power to the boiler? aND would restore power to the boiler when the washing machine is switched off?
  • #2 16244082
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    A priority relay must be used.
