Huawei b593s-22 Slow Internet in Jaromierz: Improve LTE Speed, Antenna Options & Net Settings
lobo00 5196 4
  • #1 16255572
    lobo00
    I live in Jaromierz on Lawendowa. I got the huawei b593s-22 router and bought a card for the net with a plus. The problem is the very slow internet, I have 3 LTE lines on the router, but the data reception is only about 0.5 Mb / s. When I switch to 3G, I only have one bar, but sometimes I have 2Mb / s net. Today only 0.04Mbps. How to set up the router and where the transmitters are. Possibly what external antenna to buy because I heard that it all depends on the transmitters. Thanks in advance for your help.
  • #2 16255729
    kermit_
    You use a loaded BTS and therefore the Internet is slow, and you must choose the antenna to the frequency you use.
    http://beta.btsearch.pl here you can check what and where your transmitter is
  • #3 16255802
    matek451
    Help: 4352
    Rate: 5808
    Move the card to the phone with LTE with the Network Cell Info application, check the LTE signal parameters and data of the BTS you are connecting to. Indoor and outdoor test. Show the screen, plus speed tests. Why did you choose Plus? "Famous" for overloaded LTE BTSs. The nearest permit for LTE1800aero2 and LTE800sferii in Jaromierz. Other same in Gardeji-Wanadowo. It's hard to say if they work. Do the tests on the phone also under them in your direction. The LTE800 Sferia is assumed to be slow, the 5MHz band in MIMO with an overloaded BTS does not allow much. The B593s-22 does not have the ability to force LTE bands.
  • #4 16257318
    lobo00
    Thanks a lot. Unfortunately, I had to leave, but as soon as I come back I will do what I need and post screenshots.
  • #5 16279686
