[Solved] Sharp Aquos LC-40LE824E Power Supply Issue: Replaced Electrolytic Capacitors, Still Fails
tporem 8982 9
What should I check in a Sharp Aquos LC-40LE824E power supply that still shuts down after replacing all electrolytic capacitors?
The fault was a bad optocoupler in the power supply feedback loop, not the electrolytic capacitors. One of the four optocouplers between the primary and secondary sides was defective: there was voltage at the LED anode, but no proper collector-emitter drop, and shorting collector to emitter made the TV start normally [#16448980] The failed part was replaced with an LTV-817, and all four optocouplers were replaced just in case [#16448980] A service manual exists for the RUNTKA685WJQZ / DPS-126CP supply and can help with diagnosis of the LED driver and related circuits [#16256624]
  • #1 16252604
    tporem
    Welcome,
    TV Sharp Aquos LC-40LE824E, for example, when increasing the brightness of the backlight or the colors to dynamic (which thus increases the brightness of the image) began to turn off and after a while it turned on again. It worked normally when set to ECO mode. After a few months, even dimming the image did not help, as it would not turn on. The TV is about 5 years old.
    I understand that the TV power supply was not producing power. Therefore, in the power supply, I replaced all electrolytic capacitors with new ones, although none of them was swollen. It helped and everything returned to normal, but after 6 months the problem returned. Now it won't even turn on. It goes out a few seconds after it is turned on.
    It seems to me that replacing the capacity may not bring the desired results. Everything looks ok on the board, nothing is overheated, I went through the diodes, they also look ok.
    Does anyone have any idea what else I should pay attention to or replace.
    ps
    The power supply has the designation DPS-126CP-1 A, RUNTKA685WJQZ
  • #2 16252891
    Dejwid Koperfilc
    Rate: 22
    "I walked the LEDs, they also look ok.
    Does anyone have any idea what else I should pay attention to or replace. "
    Traverse resistors, voltages, currents, capacities and inductances.
  • #3 16253022
    buli1
    Help: 61
    Rate: 294
    Soft check.
  • #4 16253221
    tporem
    Thanks for the hints.
    I will go through the suggested elements.
    The soft will be a problem because the TV does not start anymore, but if it worked, what should I check, its version?
  • #5 16253459
    telesat1
    Help: 104
    Rate: 258
    Ask what and how?
    buli1 wrote:
    Soft check.
  • #6 16255028
    tporem
    buli1 wrote:
    Soft check.
    Thank you for the tip, but can you tell me what and how to do it? Is it just checking the version or maybe you mean entering the service menu and checking a specific parameter?
  • #7 16255051
    sosarek
    Help: 9320
    Rate: 15541
    Soft is not a problem here, but the power supply (or matrix backlight).
    Z
    Pka, Poznań, 60-850
    lisek
    Service technician RTV
    Help: 6355
    Rate: 6886
    You have SM for this RUNTKA685WJQZ Sharp / DPS-126CP power supply
    Power Supply RUNTKA685WJQZ Sharp / DPS-126CP
    IC7801 NCP1608BDR2G
    IC7901 ICE3BS03LJG
    IC7601 ICE3BS03LJG
    IC7702 DDA003A-SG240
    Also helpful, for example, a topic from the forum Link
    You have an idea about electronics, measurement and diagnostics, e.g. LED driver, you can fix it.
    * if not, service
    * MS may be helpful to others
    • Power Supply RUNTKA685WJQZ Sharp.pdf (3.47 MB) You must be logged in to download this attachment.
  • #9 16448980
    tporem
    TV started.
    It turned out that one of the four optocouplers operating in the feedback loop between the primary and secondary parts of the power supply was broken. The more I thank my colleague for the power supply diagram.
    At the anode (diode) of the optocoupler there was a voltage that triggered the diode, and yet there was no voltage drop between the collector and the emitter.
    With a screwdriver I shorted the emitter with the collector of the suspect optocoupler and the TV started to work normally. Thus, I came to the conclusion that it is not working properly.
    Unfortunately, getting the original optocoupler was quite difficult, so I replaced it with another one with similar parameters, ie LTV-817. I replaced all 4 optocouplers just in case. The total cost did not exceed PLN 20.00 Everything was fine and I have been enjoying a normally working TV for a long time.
  • #10 17263022
    Jeziersr
    For me, the replacement of optocouplers also helped
    Thanks
The discussion revolves around a power supply issue with the Sharp Aquos LC-40LE824E television. The user initially replaced all electrolytic capacitors in the power supply, which temporarily resolved the problem. However, after six months, the TV failed to turn on again. Participants suggested checking various components, including resistors, voltages, and currents. A significant breakthrough occurred when the user discovered a faulty optocoupler in the feedback loop of the power supply. After replacing all four optocouplers with similar models, the TV functioned normally again. The total repair cost was minimal, and the user has since enjoyed a fully operational television.
