Asus Zenfone 5 Charging Issue: LED Lights Orange, Battery Level Drops, Tried Multiple Chargers
Damlits 6294 12
Why does my Asus Zenfone 5 show that it is charging, but the battery percentage still drops even after trying different chargers, cables, and cleaning the port?
This points more to a hardware problem in the charging path than to the battery itself, and the thread does not show a software fix [#16256913] [#16270640] One recommendation is to check the power consumption while the phone is charging, because the phone may still be drawing more power than it receives [#16256913] Another user with identical symptoms reported that service found liquid damage/flood indicators and treated it as a warranty/board issue rather than a charger issue [#16259846] [#16261806] In the same case, the service only managed to charge the phone temporarily after blowing it out, but the fault returned, which also suggests an intermittent hardware defect [#16270640]
  • #1 16255773
    Damlits
    from today problems with my phone started.
    When I connect it to charging, the LED lights orange (which means charging), the battery in the phone also shows that the phone is charging, but the percentages do not go up at all, on the contrary. It is not even maintained, only the charge level drops slowly, as if I were using a telephone.
    Connecting it to a laptop does not solve the problem, but the laptop detects the device, I can view everything, move it etc.
    The problem should not be in the battery, because it was replaced about a month ago and everything worked as it should.
    I checked other contacts, other chargers, cleaned the "plug", I run out of ideas, what could be the problem? :(
    Thank you for your help and best regards.
    Edit. I forgot to add that for about 10 minutes he caught and charged, and then again the same. It has been 12 hours since then, I tried to connect, disconnect, on off, etc., but he didn't catch the second "breath" :(
  • #2 16256100
    actin
    Help: 187
    Rate: 799
    New original battery? Is there any "eastern"
  • #3 16256282
    Damlits
    Original, because the phone was under warranty until the end of January, it was replaced by Asus :P
    Is the second thing that maybe it was supposed to "break" after the warranty period?
    The fix is still that the level is maintained when the phone is connected and I do not use it, earlier it fell a few percent, but it is probably due to resets.
  • #4 16256433
    bubu1769
    Help: 1177
    Rate: 2368
    And on charging on a turned off phone has the same symptoms?
    From what I see a problem quite common in these phones.
  • #5 16256507
    Damlits
    Yes, I left it turned off under the charger for about two hours and when I turned it on after about an hour 4% disappeared.
    The same way overnight the charger didn't drop anything, and it was turned on, and then within an hour it dropped 2%, because I used it a bit on WiFi, but it was still connected.
    I have no idea what's going on - he's crazy to the max: /
    Tests are coming to an end soon, 18% left :D
  • #6 16256766
    actin
    Help: 187
    Rate: 799
    Is your phone guaranteed?
  • #7 16256913
    bubu1769
    Help: 1177
    Rate: 2368
    It is worth checking the power consumption during charging.
  • #8 16259846
    Morgalg
    I have identical symptoms with my Zenphone Max. The phone was under warranty, so I sent it to the service and there they found it flooded, the guarantee was lost and I have to pay out of my own pocket. Anyone know how much such a repair on the site can be or what has fallen on the phone and what is to be replaced? The whole motherboard?
    edit:
    Needless to say, the phone wasn't even near the water.
  • #9 16260135
    bubu1769
    Help: 1177
    Rate: 2368
    Therefore, before sending the warranty, detailed photos are taken, especially of sensitive points.
  • #10 16261420
    Morgalg
    Well, but it's hard to take pictures of the inside of the phone as it has seals and goes for a guarantee, right?
  • #11 16261806
    bubu1769
    Help: 1177
    Rate: 2368
    The more I mean that on the phone there were no traces of water, sometimes even a special marker is visible that activates after contact with moisture, here you have their arrangement shown link (by the way, sometimes they can be activated from sweat when you have your phone on a hot day)
  • #12 16262102
    Morgalg
    It's all a bit sad. In a private service they valued me for PLN 200, in Asus they wished so much for the diagnosis of parts to be replaced ... I respect everyone's future.
  • #13 16270640
    Damlits
    Now I don't know what to do anymore, I took the phone to the service. They called me back after an hour that they had only blown it and charged up to 65% (and it was already empty). I took it, plugged it in, recharged it to 70%, then it started to fall to 50%, then it recharged to 87%, and now it does not recharge again but drops;
    I tried to reset the system, but that's not it.
    I would suspect a socket, but if it detects a connection, I can flip files, what could it be? I guess I will have to take it to another site where it won't happen, the malice of inanimate objects ...
✨ The user is experiencing a charging issue with their Asus Zenfone 5, where the LED indicator shows orange, indicating charging, but the battery percentage continues to drop instead of increasing. Despite trying multiple chargers and cleaning the charging port, the problem persists. The user replaced the battery a month ago, and while the phone was under warranty, they suspect potential issues related to the warranty period. Other users have reported similar symptoms, suggesting this may be a common problem with Asus devices. Some have experienced water damage claims despite no exposure to water, leading to costly repairs. The user has attempted various troubleshooting steps, including charging while the phone is off, but the battery continues to drain. They are considering further service options due to the ongoing issues.
