Samsung Galaxy S5 Charging Issue: Battery & Orange Triangle, Changed Battery, New Chargers
lukasz4k6 6369 2
  • #1 17128861
    lukasz4k6
    I have a problem loading Galaxy S5. I replaced the battery in the phone because I thought it was the fault of the battery, but the problem persisted. On the phone turned on and after connecting the charger (I tried on several chargers) the phone does not respond and does not charge. However, if the phone is turned off and I attach the charger, a picture appears (battery and orange triangle).
    Has anyone had a similar problem? Will it be the fault of the charging socket?
    Added after 34 [minutes]:
    And I will add that I also uploaded software updates to be sure, but it didn't help.
  • #2 17129219
    zygzag
    Rate: 76
    It looks like the battery is not connecting to the disc. Do you have a battery socket? Alternatively, see the connection between the disc and the loading plate, clean it.
  • #3 17129905
    el_danone
    Help: 21
    Rate: 25
    Replace the USB tape.
