Sony Xperia E5 Red LED Charging Issue: Not Turning On, New Battery, Compatible Chargers
tuszyn1233 4611 2
  • #1 16662774
    tuszyn1233
    Rate: 12
    Hello, patient Sony Xperia E5, the phone has a problem with charging, after connecting to the charger, the red LED lights up and displays the charging icon, but it does not charge and does not turn on the phone, I will add that the battery was changed to a new original one, it helped for some time and the phone was charging without a problem, but not on every charger (there was a problem on the original Sony), he started to charge only on the original Samsung charger. Someone had a similar case in this model, can it be fixed somehow?
  • #2 16662835
    qavr
    Help: 6
    Charging Connector?
  • #3 16662844
    tuszyn1233
    Rate: 12
    The connector looks fine, I improved February and started to charge, but also not on every charger, there is a problem on the original SONY (I tried on a few), namely it charges but the charging% does not increase, it only charges on the original Samsung charger.
