Snarling JBL Charge3 Speaker - Diaphragm and Dust Dome Play, How to Remove Dome
Dzepetto93 7044 2
  • #1 16257652
    Dzepetto93
    The problem is in the JBL CHARGE3 wireless speaker, one of the speakers started to wheeze and it does not always sound, the speaker was dismantled, I unscrewed the transducer and found that there was play between the diaphragm and the dust dome, now the question arises how to unstick, remove this dome. Regards Illustrative photo Snarling JBL Charge3 Speaker - Diaphragm and Dust Dome Play, How to Remove Dome
  • #2 16259270
    miro.nasz
    Help: 88
    Rate: 171
    Hello!
    The diaphragm coil must have play as it runs in the gap.
    Check if the spring / rubber around the diaphragm / is not damaged, if so, stick it with butaprene. There is a spring under the diaphragm, which must be connected with the membrane at the top and with the speaker basket at the bottom.
    If the loudspeaker is buzzing, there may be a scattered coil that is wound on a carcass and glued to the diaphragm.
    After sticking the diaphragm on and winding the coil / NOTE to wind the coil, you need a pin to keep the winding size of the coil / COIL works in the slot without touching the magnet.
    I use a nitro or general purpose solvent for gluing the membrane, depending on the type of adhesive glued in. By gently lifting the membranes, I apply a solvent to this gap with a brush. After removing the diaphragm and winding the coil after drying it with a film inserted together with the coil into the slot, I glue the spring and the diaphragm with appropriate glue. When it dries up, I take out the film and the speaker plays.
    The membrane can be glued with rubber or nitro glues, and the spring can be glued with nitro glue or two-component glue - depending on which it was glued.
    Regards Miro our
  • #3 16259646
    398216 Usunięty
    Help: 3925
    Rate: 9371
    miro.nasz wrote:
    The coil of the gate
    miro.nasz wrote:
    membre
    miro.nasz wrote:
    Under the diaphragm
    miro.nasz wrote:
    with the diaphragm from above
    miro.nasz wrote:
    After gluing the membrane
    miro.nasz wrote:
    For gluing the membranes
    miro.nasz wrote:
    By gently lifting the diaphragms
    miro.nasz wrote:
    membramę
    miro.nasz wrote:
    For pasting the membras
    DIAPHRAGM! There is no such thing as a membram.
