[Solved] Superb II 1.9 tdi 2010 - The fan runs all the time after the engine is off
gofer62 9600 16
Why does the radiator fan run after the engine is switched off on a cold 2010 Superb II 1.9 TDI with no fault codes?
The fan controller/module in the fan motor is likely faulty, not the temperature sensor, when the fan starts after ignition off and no errors are stored. [#16259190] [#16291441] The fan assembly has two thick power wires and two thin control wires, so you can unplug the thin ones to see whether the problem disappears; if it does, the fault is in the fan unit itself. [#16259271] A measured current draw of 1.85 A is far too high for standby/leakage current, which supports a defective fan module rather than normal operation. [#16260803] The later follow-up also confirmed the repair: the module on the fan was damaged and the fan had been running because of it. [#16291441] [#17472150]
  • Radiator fan starts after battery reconnection despite no fault codes
    #1 16258962
    gofer62
    Rate: 9
    Hello, please help me solve the problem with the engine fan running.
    After overnight parking, the engine is cold, the battery is disconnected, I connect the clamp and after 10 seconds. the fan on the radiator starts working, the key in the ignition is turned to ignition, the fan slows down after starting the engine, the fan stops working. After switching off the engine and after 10 seconds the fan starts working again. There are no errors when connected to the computer.
  • #2 16259008
    rafal35
    Help: 23
    Rate: 47
    The easiest way would be to connect with something and check for any errors. Maybe the temperature sensor is broken and gives information that the temperature is too high or out of range.
  • #3 16259095
    gofer62
    Rate: 9
    Which sensor colleague mean?
  • #4 16259190
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    It is rather not a sensor, since the fan works after switching off the ignition, the controller is in the fan motor.
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    The controller comes with two thick wires and two thin ones.
    Thick is power, thin is a plus after the ignition switch and fan speed control, probably a green wire.
    Unclip the thin ones and how it goes without them is a problem in the fan.
  • #6 16259384
  • #7 16259425
    MobilTruck
    Help: 139
    Rate: 965
    @ Falubaz1 Tak.BLS i BXE
  • #8 16259431
    gofer62
    Rate: 9
    I gave the power to the windmill for those thick for a short time and the windmill is working.
    One more question, can the current consumption of the battery be 1.85 A, that's what I measured?
    Added after 1 [hours] 36 [minutes]:
    Pictures of this fan
    • Superb II 1.9 tdi 2010 - The fan runs all the time after the engine is off IMG_20170207_151117.jpg (3.93 MB) You must be logged in to download this attachment.
    grala1
    Help: 1495
    Rate: 5052
    So it looks like the fan is broken.
    Too much consumption.
    It should be about 20mA or 0.02A
    Unless you ask about the fan current it can be.
  • #10 16261386
    gofer62
    Rate: 9
    Unclipped fan and such current measured in series by the clamp.
  • #11 16261399
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    gofer62 wrote:
    After overnight parking, the engine is cold, the battery is disconnected, I connect the clamp and after 10 seconds. the radiator fan starts working
    It's the only thing that makes me wonder why you disconnected this clamp The rest is pikuś, the fan turned on, and the electronics are awake.
  • #12 16261444
    ALIBABA I
    Help: 223
    Rate: 537
    Hello col. Strumien wrote why you disconnected the clamp
  • #13 16262789
    gofer62
    Rate: 9
    The fan is 100% damaged, I disconnected so as not to discharge the battery.
  • #14 16290035
    gofer62
    Rate: 9
    Colleagues will check one of you for what is responsible fuse f6 f7 f8 in the box in the engine compartment.
    Thanks.
  • #15 16291129
    Help: 1405
    Rate: 6430
    And what else has not been repaired?
  • #16 16291441
    gofer62
    Rate: 9
    The fan is repaired, the module on the fan is damaged, but there is a problem with the leakage of electricity.
  • #17 17472150
    gofer62
    Rate: 9
    Module defective, fan running
The discussion revolves around a 2010 Skoda Superb II with a 1.9 TDI engine experiencing an issue where the radiator fan operates continuously after the engine is turned off. The user reports that the fan activates shortly after reconnecting the battery, slows down when the engine starts, but resumes operation after the engine is switched off. Despite no error codes being detected via diagnostic tools, various suggestions are made regarding potential causes. Responses indicate that the issue may stem from a faulty fan control module rather than a temperature sensor, with recommendations to check the wiring and current consumption of the fan. The user confirms that the fan is damaged and mentions a problem with electrical leakage. The discussion concludes with a note that the fan module is defective, leading to the fan's continuous operation.
