The check engine indicator light on the Chevrolet captiva 2.2 diesel lights up
mariosiwy 7626 7
  • #1 16259818
    mariosiwy
    Rate: 17
    Hello. I have such a problem, the captivi cintrolka check engine lights up. A friend hooked up a computer and three errors were displayed: throttle, collector, throttle potentiometer. It is strange that the engine has power and the indicator lights up and after about one day goes out. I ask for advice.
  • #2 16259829
    szymitsu21
    Help: 343
    Rate: 1297
    Any error codes?
    Circumstances in which they occur?
    Parameter preview?
  • #3 16259841
    mariosiwy
    Rate: 17
    I didn't write these codes, but the parameters indicated that the throttle on the graph showed large values and the engine was idling.
  • #4 16332116
    mariosiwy
    Rate: 17
    Hello, I did another engine test codes in the picture. And what could it be?
    Anyone know what this is?
    • The check engine indicator light on the Chevrolet captiva 2.2 diesel lights up IMG_1255.JPG (2.13 MB) You must be logged in to download this attachment.
  • #5 16332131
    szymitsu21
    Help: 343
    Rate: 1297
    no throttle power supply.
  • #6 16332188
    mariosiwy
    Rate: 17
    Or do you have a throttle connection diagram?
  • #7 16343571
    mariosiwy
    Rate: 17
    After resetting the errors, the indicator light again came on but with one error P02E4.
    Is this a throttle power failure or a damaged throttle motor?
  • #8 16376586
    mariosiwy
    Rate: 17
✨ The discussion revolves around the check engine light activation on a Chevrolet Captiva 2.2 diesel vehicle. The user reports that after connecting a diagnostic computer, three error codes related to the throttle, collector, and throttle potentiometer were identified. Despite the engine maintaining power, the check engine light intermittently turns off after a day. Subsequent tests revealed a persistent error code P02E4, raising concerns about potential throttle power failure or a damaged throttle motor. Participants in the discussion inquire about specific error codes, parameters during the engine test, and the throttle connection diagram to further diagnose the issue.
